Re:Lexus LS 400 - Niềm đam mê bất tận!!!
nghe tây đồn bác Tạo có thể chữa các bệnh sau:
● problems in getting into diagnostic mode or scanner says "no communication"
● random dropping into "limp home" mode
● weird shifting problems
● OBD port is unresponsive, seems dead
● throwing random fault codes
● engine won't rev out/rev limits at 2000 or less rpm
● engine runs like crap, then suddenly runs fine again
● random not starting or cutting out
● low idle or erratic idle
● often very hard to start, requires starting fluid
● transmission will not automatically shift, only manual shift is possible
● transmission jerks from 1st to 2nd gear, and kinda slips from 2nd to 3rd
● no A/C compressor operation
● idle speed rolling up and down, or sometimes too low and sometimes too high
● speedometer not working reliably
● speed (cruise) control not working
● tachometer not working sometimes
● air bag light flickering intermittently
● A/C going into reset with flashing front defog light (front defog light typically flashing 10 times)
● check engine light on sometimes, but no codes stored, often in concert with ECT light
● ECU not communicating with scanners or not displaying codes with jumper installed
● bad sulfur exhaust smell in concert with not running right above
xe mình bị "engine won't rev out/rev limits at 2000 or less rpm" bác Tạo chữa hết trong vòng 1 note nhạc
