6.835
145
RE: Mer GL
Nói các bác không tin, em lấy số đo cụ thể này. Còn LX570 thì phải chờ thôi, chưa biết cụ thể mà. Cuối năm nay ra mắt
Lexus GX 470 : http://www.lexus.com/models/GX/detailed_specifications.html
Exterior Specs
Length (in / mm) 188.2 / 4,780
Width (in / mm) 74.0 / 1,880
Height (in / mm) 74.6 / 1,895 [16]
Wheelbase (in / mm) 109.8 / 2,790
Minimum Ground Clearance (in / mm) 8.3 / 210
Approach Angle, RAHC High 30 degrees
Approach Angle, RAHC Normal 31 degrees
Departure Angle, RAHC High 29 degrees
Departure Angle, RAHC Normal 25 degrees
Curb Weight (lb / kg) 4,871 / 2,209
Curb Weight, Third Row (lb / kg) 4,959 / 2,249
Weight Distribution (front / rear) 53% / 47%
Max Towing (lb / kg) 6,500 / 2,948 (with optional tow-hitch receiver) [5]
Towing Package Towing Prep Package [5] Optional
Max Payload (lb / kg) 1,241 / 563 (with third-row seats) [6]
1,329 / 603 (without third-row seats) [6]
Lexus LX470 : http://www.lexus.com/models/LX/detailed_specifications.html
Exterior Specs
Length (in / mm) 192.5 / 4,890
Width (in / mm) 76.4 / 1,940
Height (in / mm) 72.8 / 1,850 [14]
Wheelbase (in / mm) 112.2 / 2,850
Ground Clearance (in / mm) 9.8 / 250
Approach Angle, AHC high 32 degrees
Approach Angle, AHC normal 30 degrees
Departure Angle, AHC high 26 degrees
Departure Angle, AHC normal 23 degrees
Curb Weight (lb / kg) 5,590 / 2,535
Max Towing (lb / kg) 6,500 / 2,948 [5]
Max Payload (lb / kg) 1,270 / 576 [6]
Land Cruiser Mỹ ( y như VN nhưng VN có banh dự phòng nên kích thướng tổng thể dài hơn, cái này thì chắc các bác biết) : http://www.toyota.com/landcruiser/specs.html
Exterior Dimensions (in.)
Overall height/Overall width 73.2/76.4
Overall length/Wheelbase 192.5/112.2
Track (front/rear) 63.8/63.6
GL450 này http://www.mbusa.com/models/features/specs/dimensions.do?modelCode=GL450&class=08_GL
Exterior Dimensions
Wheelbase 121.1 in
Overall length 200.6 in
Overall height 72.4 — 75.6 in
Overall width 75.6 — 83.7 in
Ground clearance 7.9 — 10.9 in
275
RE: Mer GL
Các bác cho em hỏi xe C180k Classic có cách nào kết nối dt rảnh tay với dàn âm thanh được không.
6.835
145
RE: Mer GL
Trích đoạn: bean180K
Có bác àh, nếu xe bác có pre-wire thì mua cái MHI Bluetooth Interface ( giá gần 500 USD tại Mỹ, papa em nhờ người thân mua rồi). Muốn kiểm tra xem có pre-wire hay không thì bác mở hộp dựng đồ ra, ngăn phía trên ( mở bằng nút nhỏ ấy), nếu có đầu cắm thì xe có pre-wire. Chúc bác vui
275
RE: Mer GL
cám ơn bác mb_fan,ý bác nói là cái hộp giữa ghế lái và ghế phụ đúng không ạ.Xe em là xe LD thôi.
6.835
145
RE: Mer GL
Dạ đúng ạh. Bác mở ngăn trên ra, nếu có đầu cắm thì xe bác có Pre-wire. Em chưa đi C nhiều nên không rõ lắm.
4.039
1.555
tp.HCM
RE: Mer GL
Trích đoạn: mb_fan
Em năm nay 14 rồi, em sinh năm 1993 mà bác Air Bag.
Trời đất ơi , có thiệt khg , em nghi bác mb-fan này khai gian để trốn NVụ đó , con nít gì mà rành xe còn hơn khối người lớn , mà lại xe độc nữa chứ . 14 tuổi mà còn hỏi em cách nào lấy vợ giàu nữa chớ . hỏng tin nổi
6.835
145
RE: Mer GL
Trích đoạn: adco
Trích đoạn: mb_fan
Trời ơi, em phải làm sao để bác tin đây, chắc chụp giấy chứng minh của em quá, nhưng bác cũng không tin đâu.
Để em trả lời từng cái nha : rành xe là do em lướt web hằng ngày, đặc biệt là xe. Ba em mê xe và cũng chơi xe, từ mô tô 300 phân khối tới 800 phân khối ( trước năm 89) nên em biết được khá nhiều. Xe độc là vì em khoái xe xịn:D:D:D:D:D:D. Còn 14 tuổi mà hỏi cách lấy vợ giàu tại em phát triển sớm:D:D:D:D:D. Con nít dạo này ranh lắm, có đứa 12 mà "hiểu" như 22:D:D:D:D:D:D:D. Em nói thật đấy:):):):)
4.039
1.555
tp.HCM
RE: Mer GL
Trích đoạn: mb_fan
Trích đoạn: adco
Trích đoạn: mb_fan
Thiệt á ?? thôi để hôm nào chú gửi con chú qua chơi với em cho nó rành chuyện xe cộ và phát triển sớm như em nhé . Hồi xưa chú mà phát triển sớm thì con chú giờ chắc cũng ... cỡ em rồi :D . Chúc em học giỏi nhá , trước sau gì cũng đi du học mà phải khg , mấy bữa thấy đi mẽo chơi mà
6.835
145
RE: Mer GL
Trích đoạn: adco
Trích đoạn: mb_fan
Trích đoạn: adco
Trích đoạn: mb_fan
Cảm ơn bác nhé. Bác thích thì gửi con bác qua. Em "huấn luyện" cho. Con gái càng tốt:):):):):):):):):):) Cho em hỏi tí : con bác bao nhiêu tuổi rồi????? Em đi mẽo là để lấy visa trước, sau này đi dễ hơn. Còn du học thì em phải cố gắng thôi. Chuyện tương lai khó nói lắm. Năm sau, em phải vô Lê Hồng Phong, không thì chết với papa và mama em. Không vô được thì ko có gì hết, ko OS luôn:(:(:(:(:(
1.805
2.824
RE: Mer GL
Bác xem lại coi, e thấy Land lẩu dê dài 5,2 m trên trang web VN. lý do khác nữa là Land lẩu dê là Land VN máy I6, Lx máy V8 suy ra mõm của Land VN dài hơn mõm của LX470.Gx thì đồng ý với bác là ngắn hơn, gọn hơn,đẹp hơn
Trích đoạn: mb_fan
Exterior Specs
Exterior Specs
Exterior Dimensions
Wheelbase 121.1 in
