8.170
34.326
Discovery now rests inside the Orbiter Processing Facility bay 3 marking the completion of Mission STS-114. The Multi-Purpose Logistics Module Raffaello, will be removed from the payload bay and transferred to the Space Station Processing Facility. (Image credit: NASA/KSC)
8.170
34.326
Discovery finally rests with its wheels on the ground after the orbiter was lowered overnight from the Mate/Demate Device. (Image credit: NASA/KSC)
8.170
34.326
Closing the landing gear doors is one of the final servicing steps before lifting the Space Shuttle Discovery and mating it to NASA's 747 can begin. (NASA photo by Tony Landis)
mấy bác này đóng cửa càng bánh xe trước khi lắp nó lên mình b 747
8.170
34.326
Image to left: The External Tank leaves the Launch Complex 39 Area Turn Basin parking area on its way to the Vehicle Assembly Building. Credit: NASA
Inside the Vehicle Assembly Building, the redesigned External Tank to be used on Return to Flight mission STS-114 waits in the transfer aisle after its move from the barge in the Launch Complex 39 Area Turn Basin. (Image Credit: NASA/KSC)
8.170
34.326
@Phuoc gia: là thùng nhiên liệu chính cho ba động cơ chính của con thoi đó bác, cái này phóng lần rồi bỏ.. còn hai hoả tiển booster thì xài lại . Sau khi phóng được gần 8.5 phút thì con thoi sẽ thả bỏ bình nhiên liệu này ở độ cao 70 miles . các bác vote thì em post tiếp , còn nhiều lắm .thông tin về bình nhiên liệu
External Tank Stats
Weight:
Empty: 78,100 pounds
Propellant:
1,585,379 pounds
Gross: 1,667,677 pounds
Propellant Weight *
Liquid oxygen:
1,359,142 pounds
Liquid hydrogen:
226,237 pounds
Gross: 1,585,379 pounds
Propellant Volume *
Liquid oxygen tank:
143,060 gallons
Liquid hydrogen tank:
383,066 gallons
Gross: 526,126 gallons
8.170
34.326
An aluminum tank from space shuttle Columbia's STS-107 mission was uncovered recently when Lake Nacogdoches receded during an ongoing drought. Photo courtesy of Nacogdoches Police
bình nhiên liệu bằng nhôm cũa tàu con thoi columbia bị nổ khi về trái đất nay được khai quật khi nước hồ rút xuống trong mùa khô hạn
8.170
34.326
Image above: Freedom Star tows the booster back to shore for refurbishing. Image credit: NASA/Jim Grossmann
thâu hồi hoả tiễn booster sau khi phóng tàu con thoi
Image above: The left spent booster from space shuttle Discovery's final launch bobs in the Atlantic Ocean near the Freedom Star. Image credit: NASA/Ben Smegelsky
