Club/Khoe Xe Nhật ký SUSTI!
Re: Chặng đường Subaru Impreza WRX STi 2011 tại Việt Nam
@bác rồng: câu hỏi của bác là vấn đề vẫn đang còn tranh cãi khá gay gắt, mời bác xem qua topic này nhé: http://forums.nasioc.com/...howthread.php?t=437237
Về việc có nên lắp hay không thì cuối cùng vẫn tùy quan điểm của mỗi người thôi. Còn quan điểm của em thì em sẽ lắp vì 1. Đẹp! 2. Nhẹ! 3. Chưa có ai bị hỏng máy vì thay lightweight pulley mà máy boxer thì không cần harmonic dampening! :D
Quote:
Thank you for your patience as I checked with our Technical Services
Department regarding your message below. They advised that the crank pulley
is a pulley and nothing else. It is not used as a harmonic damper/balancer.
Thanks for the opportunity to be of assistance. If you need any future
assistance, please feel free to contact us again.
Best wishes,
John J. Mergen
Subaru of America, Inc.
Pulley FAQ
The primary purpose of an aftermarket pulley is to reduce the size and/or mass of the stock unit. They serve two purposes: to reduce horsepower loss and increase throttle response. Notice the use of "reduce horsepower loss". Pulleys DO NOT add horsepower, rather they free up horsepower due to the reduction of rotational mass.
HP gain is 5-10HP. These HP figures are a range as there have been very few before/after dyno runs with lightened or under driven pulleys.
What is a lightened pulley? Generally, it is an exact copy of the OEM pulley only CNC machined out of aircraft grade aluminum and powder coated for corrosion protection and aesthetic appeal.
What is an under driven pulley? This is a pulley that mimics the function of the OEM unit, but is smaller in diameter. This will reduce the duty cycle of the pulley and proportionally the parasitic drag on the engine.
Are under driven pulleys bad? It depends on the amount they are under driven. Some under driven pulleys can lead to reduced A/C output, lighting problems, stereo problems, and other voltage issues. Some are lightly under driven and some more so.
Isn't replacing the stock harmonic damper (pulley) bad? Subarus do not come with a harmonic damper or balancer like some other vehicles do. For other manufacturers' vehicles, this is a legitimate concern. Proof:
"Thank you for your patience as I checked with our Technical Services Department regarding your message below. They advised that the crank pulley is a pulley and nothing else. It is not used as a harmonic damper/balancer.
Thanks for the opportunity to be of assistance. If you need any future assistance, please feel free to contact us again."
Best wishes,
John J. Mergen
Customer Service Department
Are there any downsides to these pulleys? There have not been significant amounts of problems with pulleys. There have been some reports of high RPM issues with pulleys though. These issues tend to happen without regard to type or manufacturer. It possibly stems from rotational issues with the crank position sensor which is located near the pulley. The indication of error is a reduction of the fuel cutoff redline of the motor (false redline). The solution is to reinstall the stock pulley. As with any aftermarket part, even "perfect" ones, sometimes you run into a rogue issue. From research, this is not a widespread issue at all, only an advisory if this situation should occur.
Which manufacturer is best? This topic is highly debated. There have been no reported consistent "bad" pulleys on the market. Obviously, there may have been bad pulleys sold, but not enough to report as "bad" overall.
Which pulleys have the best gains? There is no irrefutable evidence that any pulley set has better gains than another. That being said, it stands to reason that a lighter pulley has more gain than a heavier competitor. Under driven would also free up more power than standard size.
Where do I buy a pulley or pulley set? Every Subaru/Import performance store sells pulleys. For purchasing, support your local economy or the NASIOC Vendors.
How hard is it to install a pulley or pulley set? Allow around one hour for install time. Professional installation, depending on your area, is around $75. This is one vehicle modification that is very simple and can be successfully accomplished by even the greenest shade tree mechanic.
How do I install a pulley or pulley set? Refer to the pulley manufacturer's instructions. For pulleys without instructions, many rely on the Vishnu instructions for installation. Below are links to some of the better known pulley installation instructions:
Vishnu's Instructions (contained inside the Stage Zero Instructions)
scoobymods.com instructions (with photos)
EDO Performance instructions (with photos)
Perrin Performance instructions (with photos)
Should I reset my ECU after this mod? It is never a bad idea to perform an ECU reset after a mod. The traditional route is to disconnect the negative battery terminal, press the brake pedal for a few seconds to bleed the system of charge, and reattach. Some use the more advanced Vishnu Reset.
Editors Note
This post was created because I wasn't able to find a good pulley FAQ. I came up with the text based on LOTS of searching here. It was also created to be intentionally brand neutral so that it serves as a stepping stone for further research. Upon reading this you should have an idea of what type of pulley best suits your needs. The manufacturer is up to you.
If you find an error in this FAQ, please PM me with factual details and I will update this post. Responses such as, "I have XXX's pulley and it's great!" or "XXX's pulley is all wobbly" are not appreciated here, that is what the Car Parts Review Forum is for.
1.701
356
HCMC
SAFETYFAST nói:
Em cũng nghiêng về hướng muốn lắp đó bác nhưng còn ngại điều kiện đường xá bên mình không biết có ngoài dự tính của giới aftermarket bên Mỹ hay không ;), nhất là xe em thường đi đường xấu, dã ngoại, mò mẫm. Theo em hiểu stock pulley của Subaru vẫn là loại hai phần có lớp cao su ở giữa (như kiểu damper) như các loại xe khác ạ. Nếu không cần damping thì sao Subaru không làm cái này ngay từ đầu khác đi...
1.701
356
HCMC
SAFETYFAST nói:
Còn đây là cái mặt gương trong xe mà bữa trước em định nhượng lại nhưng rốt cuộc lại tự gắn lên xe luôn, thời gian gắn lên mất 3 phút mà cái này em thấy rất ổn, dịu mắt và tăng góc nhìn gấp đôi gương thường, buổi tối mà xe sau có bật pha cũng không bị chói! (mỗi tội là giá hơi đắt tí)
Mặt gương Prova bác dùng mấy hôm vẫn thấy ổn chứ bác :)? Em đang nghĩ xem nên mua cái này hay tiếp tục tìm dây nối adapter cho cái auto-dimming compass mirror. Chắc là nó fit xe em luôn bác nhỉ.
3.421
16.736
Ủa nó k có sẵn hả bác? Em tưởng nó có sẵn chứ. Để mai em mở cái Legacy của em ra coi thử. Vừa phải đặt mua cái adapter để gắn cái gương lên.
3.421
16.736
Em tính order mấy thứ trên japanparts về (núm prova, mặt gương prova cho hai bên và bộ pedal sti). Có bác nào mua gì không làm luôn một lần ah? Hiện tại 3 món đó ship nó tính em 50usd rồi, nên bác nào mua cái gì nhè nhẹ thì em để ké theo em luôn
@richievn: bác từ từ bình tĩnh để em với bác cachiva cùng đặt vô lăng D-shape luôn được không? Japanparts thì tốt, chỉ mỗi tội là không có D-shape của GTspec thôi! :D
411
123
Switzerland
SF: mình order steering wheel của prova rồi bạn ơi. Mình ko lấy D shape mà lấy O. Hàng tuần sau về rồi. Ah free ship trong us nhé vì bill over 750 thì phải. Tí check lại
GTspec ko ổn vì dùng tg dài vô lăng sẽ bóng nhẫy hiiii. Được mỗi cái carbon nhìn hấp dẫn.
Sau hôm qua về hết thêm mớ tiền. Vụ turbo timer và water methanol injection mình để gần tết mua rồi bạn cần mình sách tay về luôn nhé SF. Mình còn một đot hàng mỹ về gần tết nữa yên tâm.
P/s: turbo timer của apexi có vẻ ko đẹp bằng hks bạn ah
