Re:Tham gia diễn đàn đã lâu nhưng toàn coi ké. Hôm nay em mới đủ điểm up hình tham gia.
Chết, hôm qua không có lên diễn đàn, khang lỡ đánh bằng cana rồi. Không biết có sao k? Đánh lên thì thấy xe bóng lắm, che được các vết trầy nữa.
arque (make)
Peugeot
Issued from
1987
Model
405 1.9 GL
Serie
405
Manufacturer
Peugeot S.A.
Country
FR
Сar's Body:
Number of doors
Bodywork type
sedan (saloon)
Number of seats
Bodywork designer
Pininfarina
Passenger space (volume)
4570 l / 161.39 cu ft / 161.39 cu ft
Dimensions:
Length
4407 mm / 173.5 in / 173.5 in
Total (curb) weight
1020 kg / 2249 lb / 2249 lb
Width
1692 mm / 66.6 in / 66.6 in
Height
1407 mm / 55.4 in / 55.4 in
Wheelbase
2669 mm / 105.1 in / 105.1 in
Track front
1450 mm / 57.1 in / 57.1 in
Track rear
1435 mm / 56.5 in / 56.5 in
Length/wheelbase ratio
1.65
Aerodynamics:
Drag coefficient (Cd, Cx, Cw)
0.3
Frontal area (A)
2.02 m2 / 21.8 sq ft / 21.8 sq ft (est.)
Aerodynamic coefficient (Cd×A)
0.61 m2 / 6.5 sq ft / 6.5 sq ft (est.)
Aerodynamic resistance (Aero horse power) at 100 km/h (62 mph)
15.1 kW / 20.2 hp / 20.2 hp (est.)
Engine Information:
Total number of cylinders
Engine Type
straight (inline) (Inline, 4 cylinder)
Total number of valves
Engine Manufacturer
Peugeot
Valves per cylinder
Bore
83.0 mm / 3.27 in / 3.27 in
Fuel
petrol (gasoline)
Stroke
88.0 mm / 3.46 in / 3.46 in
Bore/Stroke ratio
0.94
Engine displacement
1905 cm3 / 116.3 cu in / 116.3 cu in
Unitary capacity
476.25 cm3/cylinder / 29.063 cu in/cylinder / 29.063 cu in/cylinder
Cam Design
SOHC (single overhead camshaft)
Compression ratio
9.3 : 1
Max. output power
82.0 kW / 110.0 hp / 110.0 hp at 6000 rpm / 6000 rpm / 6000 rpm
Aspiration
natural
Max. torque
162.0 N·m / 119.5 lb·ft / 119.5 lb·ft at 3000 rpm / 3000 rpm / 3000 rpm
Compressor type
N/A
Intercooler
no
Max. net output (power at the wheels)
45.4 kW / 60.9 hp / 60.9 hp (est.)
Coolant
water
Specific output
43.0 kW/l / 0.946 bhp/cu in / 0.946 bhp/cu in
Catalytic converter
no
Specific torque
85.0 N·m/l / 0.74 lb·ft/cu in / 0.74 lb·ft/cu in
Transmission:
Transmission type
manual
Number of gears
Wheel drive
front wheel drive
Productivity:
Top (maximal) speed
185 km/h / 115 mph / 115 mph
Acceleration 0-60 mph (97 km/h)
9.20 s / 9.20 s / 9.20 s
Power-to-weight ratio
107.8 kW/ton / 81.7 bhp/ton / 81.7 bhp/ton
Acceleration 0-100 km/h
10.20 s / 10.20 s / 10.20 s
Chassis:
Engine location
front
Engine alignment
transverse
Suspension front
Independent, MacPherson strut, Anti-roll (anti-sway) bar (ARB)
Suspension rear
Independent, Trailing arm, Torsion bar, Anti-roll (anti-sway) bar (ARB)
gởi anh em 1 số thông tin cơ bản về xe peugeot ma K sưu tầm được trên mạng
arque (make)
Peugeot
Issued from
1987
Model
405 1.9 GL
Serie
405
Manufacturer
Peugeot S.A.
Country
FR
Сar's Body:
Number of doors
Bodywork type
sedan (saloon)
Number of seats
Bodywork designer
Pininfarina
Dimensions:
Length
Total (curb) weight
Width
Height
Wheelbase
Track front
Track rear
1.65
Aerodynamics:
0.3
Frontal area (A)
Engine Information:
Engine Type
Engine Manufacturer
Peugeot
Valves per cylinder
Bore
Fuel
petrol (gasoline)
Stroke
Bore/Stroke ratio
0.94
Engine displacement
Unitary capacity
Cam Design
Compression ratio
9.3 : 1
Max. output power
Aspiration
natural
Max. torque
Compressor type
N/A
Intercooler
no
Coolant
water
Specific output
Catalytic converter
no
Specific torque
Transmission:
Transmission type
manual
Number of gears
Wheel drive
front wheel drive
Productivity:
Top (maximal) speed
Chassis:
Engine location
front
Engine alignment
transverse
Suspension front
Suspension rear
Dán rồi bác vũ ơi, hom nay cho ong bạn mượn xe đi SG chơi rồi.
Mai về chụp hình úp lên cho các bác xem.
Bác Khang mua logo này phải không.
Cái logo và móc khóa mua chổ Thiên ân hơn một năm rồi giá hai cái 150.000, hai cái đều không sử dụng đúng chổ của nó.
Dúng rồi, Khang mua logo như trong hinh vậy, dán len capo nhin cũng ngầu xe lắm. Móc khóa thì chưa có mua.
Khang mới chơi xe peugeot thôi, nhưng khang thấy dòng xe này cũng ổn định, chay đầm, hôm trước cho tưng mấy dóc cầu ở đường dẫn lên cầu Cần Thơ cũng đã lắm. Lên dóc cầu Cân thơ kéo 110 khỏe re hà. Có điều xe của Khang tiếng máy nổ nghe không êm, có vẻ không đồng 4 piston. Hôm trước mới thay cam mà chạy tiếng máy cũng chưa êm. Xe cách âm cũng khá tốt, nên ngồi trong xe thì êm lắm. Máy lạnh thì ok, chạy một chút lạnh muốn run, phải tắt mới chịu nổi.
Anh em nào rành giúp khang khắc phục tiếng máy nổ xe với.
