52
34
Super ODB2 có giúp tiết kiệm nhiên liệu như quảng cáo?
Hi các bạn. Mình thấy quảng cáo bán cục super OBD2 cắm vào cổng OBD2 trên xe. Có thể giảm 20% tiêu hao nhiên liệu.
Có bạn nào xài thử chưa?
Super obd2 chip tuning box - rm150 Only !!!
Yellow for Petrol vehicle
Red for Diesel vehicle
Super OBD2 is a Plug&Drive Ready device to function the increasing the performance of engine.
Super OBD2 is easy to install. Just plug it into the OBD2 connector of cars. Super OBD2 fits all car from the year of 1996.
It works based OBD2 protocols as remaping the Car's computer ECU. After driving 200 km road total, Super OBD2 adjusts itself to the car,
according to the drivers' habits and always keeps remaping the ECU to increase the performance of engine.
What does Super OBD2 make?
According to your driving habits, Super OBD2 makes new map in the car's computer ECU to increase the performance of your car.
As you driving much more KM/Mile, it renews the map. Thus it keeps the vehicle's power and torque increasing.
What is Super OBD2 Chip Tuning Box?
Super OBD2 is a Chip Tuning Box which can be plugged into OBD2 connector of your car to increase the performance of your car.
When it's plugged into OBD2 connector, Super OBD2 receives the information from the car's computer ECU. With the received data from ECU,
Super OBD2 adjusts the boost pressure, quantity of fuel, injection timing and pressure to increase the performance of your car.
Super OBD2 Chip Tuning Box does not exceed the manufacturer's requirements. It works only within the tolerance of the engine.
Super OBD2 finds out the hidden power of your car. Super OBD2 does not damage the engine and the cars computer ECU or not cause any negative effects to the car factory setting.
Super OBD2 does not change any of the settings permanently. To turn back to the car's original settings, just unplug Super OBD2 from OBD2 connector.
- Up to 35% more power
- Up to 25 % more torque
Super OBD2 is very easy to use.
Plug Super OBD2 into OBD2 connector of your car. And turn the ignition on for 30 seconds. And Turn the engine on.
Super OBD2 settings are optimal and the best for your car. Even the parameters are different for each vehicle,
there might not be a need to make an additional adjustment. Super OBD2 will recognize your vehicle and your driving habits after around 200 km/150 miles driving,
and then Super OBD2 adjusts itself to match your car perfectly.
Super OBD2 works on the basis of changing the signal form ECU. As a consequence, it changes the whole injection map.
The main difference between Super OBD2 Chip Tuning Box and Remapping tuning methods is that Super OBD2 Chip Tuning Box is easily removable,
and after unplug you go back to the factory settings. Super OBD2 is the cheap and safe type of tuning.
Remapping is a permanent change to your car. This is the expensive tuning and you cannot remove it.
Super OBD2 is equipped with the engine protection function and 100% safe for your car engine.
Super OBD2 produced on the printed circuit board in SMD technology. Super OBD2 Chip Tuning Boxes are high quality.
Installation and Calibration
1 - Pull the Car Key out from the ignition.
2 - Find OBD2 connector(*) in your car and Plug in Super OBD2
3 - Insert the key into the ignition and twist the key to the first stage. (Do not start the car)
4 - Press the reset buttom for about 5 sec. After releasing the buttom, just wait for a while about 30-54 sec. (Super OBD2 will communicate and establish connection with ECU)
5 - Start up the engine.
6 - Super OBD2 will recognize your vehicle and your driving habits, after around 200 km/150 miles driving and thus Super OBD2 will adjust itself to match your car perfectly for more fuel saving.
  • Haha
Reactions: nta139
285
298
73
Hàng China phải không?
Trên mấy trang youtube nước ngoài, tụi nó thử rồi không hiệu quả nên không khuyên dùng.
Trang otofun cũng có lão mua thử rồi nhưng cũng không đánh giá cao và cũng không cảm nhận được.
Nói chung là cục này có nhiều tính năng quảng cáo ghê lắm, nào là tăng torqe, tăng công xuất, giảm tiêu hao... nếu mà được như vậy thì mấy hãng độ động cơ nó đóng cửa hết rồi.
941
1.061
Thủ Dầu Một, Bình Dương
Em lạy, cái mạch điều khiển do một anh chả biết nó sẽ cắm trên con xe gì làm ra mà bảo là giảm tiêu hao nhiêu liệu bla bla bla. Hãng nó làm đủ cách từ cải tiến van nạp van xả, thay thế vật liệu mà ko làm cho xe tiêt kiệm hơn nổi mà với một thiết bị plug n play nhỏ xíu lại làm được thì nguyên cả bộ phận RnD và performance của mấy hãng xe nên nghỉ hết đi ah. Làm hao hơn như bơm thêm nhiên liệu, chuyển số chậm hơn cho nó bốc hơn thì được chứ còn dư lày làm giảm tiêu hao không tin dc đâu bác ah.
7.368
16.366
dc hãng nó làm lâu lắc rồi,, chứ cần đâu eco rồi tắt xi lanh... buôn bán có tâm chút add ơi
Reactions: duchuy19762003
12.377
27.448
Pháp
Mấy cái đó mà ra chắc là hãng xe dẹp tiệm hết, nó có thể tăng vài con ngựa, hút thêm nhiên liệu (có thể đụng đến chương trình ECU).
Theo tôi nó là mẹo đánh lừa ECU mà thôi .... Thân!
109
5.585
95
12
dĩ nhiên là lùa gà
mấy hãng xe đổ cả tỉ đô ra nghiên cứu may ra rút được chỉ số tiêu hao nhiên liệu xuống một tí, đây gắn 1 cục vớ va vớ vẩn mà đòi tiết kiệm
đúng là trứng đòi khôn hơn vịt
còn thằng ngu nào gắn thì kệ nó
