RE: Tình yêu xe cổ: Rolls Royce giai đoạn trước thế chiến 2...
Dòng Standard:
-10hp /15hp /V8 20hp (1904-1906)
-Twenty (1922-1929)
-20/25 (1929-1936)
-25/30 (1936-1938)
-Wraith (1938-1939)
Rolls Royce 25/30 HP 1936-1938
(Dòng Standard thứ 3)
Manufacturer Rolls-Royce Ltd
Production 1936-1938 / 1201 xe
Predecessor 20/25
Successor Wraith
Engine(s) 4257 cc
Transmission(s) 4-speed manual
Wheelbase 132 inches (3.4 m)
Series / Year:
GUL 1 – 81 1936/37
GTL 1 – 81 1936/37
GHL 1 – 41 1936/37
GRM 1 – 81 1936/37
GXM 1 – 81 1936/37
GGM 1 –41 1936/37
GAN 1 – 81 1936/37 New type steering controls
GWN 1 – 81 1936/37
GUN 1 – 41 1936/37
GRO 1 – 81 1937
GHO 1 – 81 1937
GMO 1 – 41 1937
GRP 1 – 81 1937 Deturbolated cylinder head
GMP 1 –81 1937
GLP 1 – 41 1937
GAR 1 – 81 1937/38
GGR 1 – 81 1938
GZR 1 – 41 1938
The Rolls-Royce 25/30 built between 1936 and 1938 is an updated version of the 20/25 with larger engine to provide more power, as often, over-large bodies had been fitted to the earlier model leading to complaints about its performance.
The in-line 6 cylinder, overhead valve, engine is similar to that used in the 20/25 but increased in capacity to 4257 cc by increasing the bore from 3.25 inches (82.6 mm) to 3.5 inches (88.9 mm) with the stroke remaining at 4.5 inches (114.3 mm). The compression ratio is 6:1. A single proprietary Stromberg downdraught carburettor replaced the Rolls-Royce one and magneto ignition was no longer fitted but a standby coil was provided. The four speed gearbox is mounted in unit with the engine and a traditional right hand change used. Synchromesh is fitted to third and top gears.
The riveted chassis has rigid front and rear axles suspended by half elliptic springs with hydraulic dampers. Braking is on all four wheels assisted by a mechanical servo, famously under licence of Hispano-Suiza. Separate rear brakes are fitted for the handbrake. The traditional Rolls-Royce radiator with triangular top was used with vertical louvres, the angle of which is controlled thermostatically to control engine cooling.
Only the chassis and mechanical parts were made by Rolls-Royce. The body was made and fitted by a coachbuilder selected by the owner.
Dòng Premium:
30hp (1905-1906)
40/50hp Silver Ghost (1906 – 1926)
Phantom I (1925-1931)
Phantom II (1929-1935)
Phantom III (1936-1939)
Rolls Royce Phantom III 1936–1939
(Dòng Premium thứ 4)
Production 1936–1939
727 produced
Predecessor Phantom II
Successor Silver Wraith
Phantom IV
Class Luxury car
Engine(s) 7338 cc V12
Wheelbase 142 in (3607 mm)
Chassis Series Year
3 AZ 20 – 238 1936
3 AX 1 – 201 1936
3 BU 2 – 200 1936/37
3 BT 1 – 203 1937
3 CP 2 – 200 1937
3 CM 1 – 203 1937/38 Petrol pump in frame from 3 CM 35
3 DL 2 – 200 1938/39 18 X 5 tires from 3 DL 78
3 DH 1 – 11 1939 Overdrive from 3 DL 172
The III was distinguished by its aluminium alloy V12 engine. With a bore of 3.25 inches (82.5mm) and a stroke of 4.5 inches (114.3mm), the new twelve displaced 447in³ (7.34L). It was a pushrod engine with overhead valves operated by a single camshaft in the valley between the cylinder banks. Early cars had hydraulic tappets, these being changed to solid adjustable tappets in 1938. The Phantom III is unusual as it has twin ignitions, with two distributors, two coils, and 24 spark plugs. Fuel is provided by a twin SU electrical pump.
Wire wheels are fitted as standard, but many cars carry Ace wheel discs.
The car featured on board jacking and a one-shot chassis lubrication system, operated by a lever inside the drivers compartment.
Another major feature was front independent suspension. This coil spring- based system was complemented by a carryover semi-elliptical spring unit in the rear.
A 4-speed manual transmission with synchromesh on gears 2, 3, and 4 was used. Overdrive was added in 1938. 4-wheel servo-assisted brakes (using a servo made under licence from Hispano-Suiza) were also specified, the brakes being applied by cable.
The radiator shell is of Staybrite steel.
1936 Rolls-Royce Phantom III
1.041
Cần Thơ City
Bác có hình của chiếc đầu tiên tại VN ko:D
