Re: RE: Đèn xenon cho C200
Các cụ OS rất lười đọc hướng dẫn sử dụng nhé. Thông tin về đèn thì đây:
Overview: changing bulbs/bulb types</h3> You can replace the following bulbs:
Halogen headlamps
Bulb type
Dipped-beam headlamps: H7 55 W
Main-beam headlamps: H7 55 W
Side lamp/parking lamp: W 5 W
Turn signal lamp: PY 21 W
Bi-xenon headlamps*
Bulb type
Tail lamp with/without LED*
Bulb type
Rear foglamp/side marker lamp: P 21 W
Side marker lamp: W 5 W
Turn signal lamp
(Vehicles with LED turn signal lamps*: the bulb cannot be changed.)
: PY 21 W
Side lamp/brake lamp/tail lamp: P 21 W
Brake lamp/tail lamp: P 21 W
Reversing lamp: P 21 W/W 16 W
(Estate: vehicle without LED* turn signal lamps (W 16 W)/vehicle with LED* turn signal lamp (P 21 W))
Changing the front bulbs</h3> Dipped-beam headlamps (halogen headlamps)[/h4]
Switch off the lights.
Open the bonnet.
Turn housing cover
anti-clockwise and remove it.
Pull connector
from bulb
Detach retaining spring
downwards.
Remove bulb
Insert the new bulb.
Attach retaining spring
Attach connector
to bulb
Place housing cover
back on and turn it clockwise until it engages.
Main-beam headlamps[/h4]
Open the bonnet.
Turn housing cover
Push bulb
on connector
down until it is released.
Pull connector
from bulb
Attach connector
to new bulb
Align new bulb
at the bottom and push connector
upwards until it engages.
Align housing cover
and turn it clockwise.
Side lamp/parking lamp[/h4]
Open the bonnet.
Turn housing cover
Pull out bulb holder
Remove the bulb from bulb holder
Insert the new bulb into bulb holder
Insert bulb holder
Align housing cover
Turn signal lamp[/h4]
Open the bonnet.
Turn bulb holder
Turn the bulb anti-clockwise, applying slight pressure, and remove it from bulb holder
and turn clockwise while applying slight pressure.
Insert bulb holder
into the headlamp so that retainer
is horizontal and marking
is at the top.
Insert bulb holder
Changing the rear bulbs</h3> Opening and closing the side trim panels[/h4] You must open the side trim panel in the luggage compartment/boot before you can change the bulbs in the tail lamps.
Saloon[/h5]
Left-hand side trim panel
Right-hand side trim panel
To open: [/b]turn catch
90° in the direction of the arrow and remove side trim panel
To close: [/b]insert side trim panel
and turn catch
90° in the opposite direction to the arrow.
Estate[/h5]
To open: [/b]turn release button
and press it down firmly until it snaps into place.
Changing the tail lamps[/h4] Saloon[/h5]
Open the boot.
Open the side trim panel more.
Saloon
Simultaneously press retaining lugs
in the direction of the arrow and slightly pull out the bulb holder with the bulbs.
Vehicles with LED turn signals: [/b]disconnect the cables of the LED turn signal from the bulb holder connectors.
Pull the bulb holder out with the bulbs.
Saloon: bulb holder without LED turn signal
side marker lamp
Turn signal lamp
Reversing lamp
Rear foglamp/turn signal lamp/parking lamp/brake lamp/tail lamp/reversing lamp:[/b] press the respective bulb back and turn it in an anti-clockwise direction to remove it from the bulb holder.
Side marker lamp: [/b]remove bulb
Rear foglamp/turn signal lamp/parking lamp/brake lamp/tail lamp/reversing lamp:[/b] insert the new bulb into the bulb holder and turn it clockwise.
Side marker lamp: [/b]insert the new bulb into the bulb holder and press it in.
Vehicles with LED turn signals: [/b]connect the cables of the LED turn signal to the bulb holder connectors.
Insert the bulb holder again and lock it in.
Close the side trim panel more.
Estate[/h5]
Open the luggage compartment.
Estate
Estate: bulb holder without LED turn signal lamps
side marker lamp
Turn signal lamp
Reversing lamp
Rear foglamp/turn signal lamp/parking lamp/brake lamp/tail lamp:[/b] press the respective bulb back and turn it in an anti-clockwise direction to remove it from the bulb holder.
Side marker lamp/reversing lamp: [/b]remove bulb
Rear foglamp/turn signal lamp/parking lamp/brake lamp/tail lamp:[/b] insert the new bulb into the bulb holder and turn it in clockwise.
Side marker lamp/reversing lamp: [/b]insert the new bulb into the bulb holder and press it in.
Halogen headlamps
Bulb type
Bi-xenon headlamps*
Bulb type
Bulb type
: PY 21 W
Saloon[/h5]
Estate[/h5]
Estate[/h5]
