TKM confirmed
2.139
18.368
Các bác coi giá Toyota Fortuner ở Dubai thử:
Toyota Fortuner SR 2.7L Benziner 158PS 4WD, Modell 2008: Body dimensions (mm): 4695 X 1840 X 1795
2.7Ltr, 4 Cyl, 16 V, DOHC, EFi, VVTi engine
Suspension Fr/Rr: Double Wishbone/4-Link Coil
Fuel Tank Capacity: 65 Ltrs
5-Speed Manual & 4-Speed Auto Transmission
7 seater configuration (2+3+2)
Adj. Intermittent Fr. Wipers
Air Conditioner: Dual
Audio: AM/FM ETR Cassette 4 Speakers
Console box with Lid
Digital clock
Door outside handle: Chrome plated
Fabric Seat material
Foot rest for Driver
Front personal lamps
Fuel lid opener
Glove Box with Key
Headlamps: Multi-reflector, Halogen
High mount stop lamp
Inner rear view mirror: Electro-chromic type
Mudguards: Fr+Rr
Power & Tilt steering
Power Window
Radiator Grille: Colour+chrome
Rear Headrests: 2+2
Rear seat (2nd row): 60:40 (Tumble & Slide)
Rear seat belt (2nd row): 3PELRx2+2PNRx1
Rear spoiler
Seat vertical adjuster: Driver
Side stripe
Sunvisors: D+P (D w/Holder+P w/ Mirror)
Urethane Steering Wheel & Shift lever knobs
Airbags for Driver and Passenger Seat
Clean Air Filter
<h2> </h2> CD / MP3 player
Fog Lamps
Keyless entry system
W/O Instrument panel upper box
Toyota Fortuner SR Special 4.0L V6 24V Benziner 235PS 4WD, Modell 2008: Body dimensions (mm): 4695 X 1840 X 1850
> 235 HP/ 5200rpm
5-Speed Manual & 5-Speed Auto Transmission
Exhaust emission control: Step 3
Meter illumination control
Rear license plate garnish: Chrome plated
Superior seat material
W/O CD player
W/O Rear parking Sensors
Toyota Fortuner SR Super Special 4.0L V6 24V Benziner 235PS 4WD, Modell 2008: 6 Speaker Audio system
Alloy Wheels
CD / MP3 player
Multi information display
Cruise control (A/T only)
<h2>in verschiedenen Farben auf Lager </h2> <h2>Automatikgetriebe nur US$ 35.690,- // Euro 23.020,- // Bruttoendpreis : Euro 32.900</h2> <h1> </h1>
<h1>Fortuner Diesel 3.0L (1KD-FTV) </h1> [font="arial;"][lang="de"]
Type Direct Injection, 4-Cylinder In-Line, DOHC 16 Valve,
Variable Nozzle Turbo with Intercooler.
Displacement cc 2,982
Maximum Output Ps/rpm 163/3,400
Maximum Torque Nm/rpm 343/1,400 - 3,200
Transmission Gate-Type, 4-speed Automatic with ECT
Fuel System Direct Injection Common Rail (D4D)
<h2>CHASSIS
Suspension front Double Wishbone with Coil Springs and Stabilizers
Suspension rear 4-Link with coil springs and Lateral Rod
Brakes front Ventilated Discs
Brakes rear Leading-Trailing Drum
Steering System Rack and Pinion with Power Steering
Tires/Wheels 265/70 R16 7JJ Alloy with Centre Cap
Drive train Full Time 4x4 Shift on the Fly (High and Low)
</h2> <h2>DIMENSION AND WEIGHT </h2> Overall Length x Width x Height mm 4,695 x 1,840 x 1,850
Wheelbase mm 2,750
Tread: front/rear mm 1,540/1,540
Ground Clearance mm 220
Curb Weight kg 1,945
Minimum Turning Radius m 5.7
Fuel Tank Capacity 65 L
<h2>EXTERIOR </h2> Headlamps 4-Lamp Multi-Reflector Halogen
Front Fog lamps Multi-Reflector Halogen
Bumper front Color Keyed
Bumper rear Color Keyed
Front Grille Color Keyed with Chrome
Over fenders Color Keyed
Side Turning Lamp Markers
Outside Rear View Mirror Chrome (with indicator optional)
Door Outside Handle Grip Type, Chrome
Window Sash Blackout
Side Step With Step Cover
Roof Rail
Back Door Handle Garnish Chrome
Rear Spoiler
Rear Window Defogger
Rear Windshield Wiper
<h2>INTERIOR </h2> Leather Seats front Sliding, Reclining with Adjustable Headrest (2pcs) with Driver Vertical Height Adjust
Leather Seats rear # 1 60:40 Split, Sliding, Reclining, and Tumble with Centre Armrest
Leather Seats rear # 2 50:50 Split, Recline, Space-up
Leather Seat Material Full Moquette
Steering Wheel and Column 4-Spoke Leather with Airbag, Tilt-Adjustable
Meter Gauge Optitron
Instrument Panel Centre Cluster Metal Panel
Map Lamp
Shift Knob/Shift Boot Urethane
Console Box with Lid and Rear Cup holder
Cup Holders/Bottle Holder front Instrument Panel and Front Door Trim
Cup Holders/Bottle Holder rear Centre Console, Rear Door Trim, and Rear Deck Side Trim
Sun visor Driver (with Ticket Holder) and Passenger (with Mirror)
Door Inside Handle Chrome
Door Trim Moulded
Door Pockets Front and Rear
<h2>FUNCTION </h2> <h2>Power Features Windows, Door locks, Outside Rear View Mirrors
Multi-Information Meter
Accessory Power Outlet Front and Rear (12V)
Air-conditioning System Dual Automatic no heater
Key/Light On Warning (Buzzer Type)
Antenna Window, Painted Type
Vehicle Security System TVSS with Keyless Entry
Parking Sensor
CD/MP3/AM/FM
</h2> <h2>SAFETY </h2> <h2>SRS Airbag Driver and Passenger
ABS (anti lock braking system)
Seatbelts front 3-pt ELR x 2 with Adjustable Seatbelt Anchor
Seatbelts rear # 1 3-pt. ELR x 2 + 2-pt. NR
Seatbelts rear # 2 3-pt. ELR x 2
Child Protection Lock
High Mount Stop Lamp
Side door Impact Beams
</h2> <h2>OPTIONAL EQUIPMENTS</h2> Toyota Heater System (Asian spec or Europe spec)
Xenon Head Lights
TV/DVD
Wooden interior
LSD (limited slip differential)
20/22-inch alloy wheels and tires
Toyota accessories and service parts
<h2>in verschiedenen Farben auf Lager </h2> <h2>Automatikgetriebe nur US$ 36.200,- // Euro 23.350,- // Bruttoendpreis : Euro 33.330
</h2> <h1> </h1> <h1>Lederausstattung, Farbe wählbar und Sitzheizung (wenn nicht ohnehin serienmässig) gegen 1.900 USD Aufpreis möglich!!!</h1>
74
Tp.HCM
Fortuner này không phải là hậu duệ của Innova rồi !
Inn V chắc trụ lại có thể khoản 2 năm nữa ! Không biết hậu duệ của Inn sau này là em nào nhỉ ?
8.716
76.926
đây
Ford có một chiếc có thể so với Ỉn là S-max nhưng không làm ở VN, chiếc này của toy bán ~50K thì EV, Ếch vẫn sống, chiếc này cũng không phải thay Ỉn (đang bán chạy, ngu sao thay) mà có lẽ thay cho Land (Land đắt và hao xăng quá)
217
FFC
saigonlounges.com
thiệt tình là e thấy em Toy này xấu đau xấu đớn, cứ y như em Ỉn tập tạ cuồn cuồn lên vậy, chả hiểu Toy có bộ phận thiết kế o hay chỉ lôi Ỉn ra đắp thêm cục này cục nọ vô nữa [:'(]
nhưng mà chắc rồi sẽ lại chạy đầy đường thôi, Toy in VN mà!
652
Xì goòng
Nhìn chiếc này thấy cơ bắp, mạnh mẽ thật. Hèn chi mấy bác trong công ty em chuộng chiếc này lắm. Công ty đã có 2 người làm chủ chiếc này rồi.
152
Lần này Toy ra 2 loại fortuner. 2.7 dầu số tay, 2.7 xăng số tự động, khoảng tháng 2.2009 sẽ giới thiệu ra thị trường. Giá khoảng 55K
152
Theo kế hoạch thì hậu duệ của Inn se ra khoảng 2012~2014, còn Inn sẽ có một lần Minor change vào 2010
481
15
Hà Nội
themxehoi nói:
Sao thằng To không lắp RAV4 nhỉ, chứ Fortuner không được đẹp cho lắm
từ h chác Toy VN chỉ lắp những xe trong dự án IMV cho các nước đang phát triển thôi bác ah. Chi phí sản xuất thấp, giá cả rẻ thì mới bán đc nhiều. Còn nhu cầu dân chơi của các bác thì cứ phải tạm hoãn lại đã. Mặc dù em rất ghét Toy ở điểm này nhưng cũng fải nói Toy VN sẽ lại thắng lớn với em Fortuner này rồi :(
481
15
Hà Nội
wasabambi nói:
Bác nói quá chính xác
Em ko hiểu sao vẫn có những bác bỏ tiền nhập em này về. Nếu sản xuất trong nuớc, giá cả hợp lý, rẻ thì mua còn được. Chứ phải bỏ cả đống tiền thuế nhập khẩu để múc em này thi em thấy hới sai lầm
