LED Tailgate Light Bar 4D- 22" (Bán tải và offroad )
Led 4D chuyên dùng cho xe SUV/ Bán tải/ offroad
Công suất: 120W
Thu gọn
Power: 120W
Protection Rate: IP67
Luminous Flux: approx 12000lm
Color Temperature: Pure White 6000K
Working Temperature: -40~85 degree Celsius
Working Voltage: DC 10~30V(fits 12V,24V vehicles)
Working Electricity: 8.93A@12V,4.46A@24V
Number of Chips: 40pcs 3W Popular PHILIPS LED
Beam Angle: Spot(30 degree)& Flood(60 degree) Combo
Size(with bracket):approx 625*120*88mm/24.6*4.7*3.4inch
Size(without bracket): approx 560*76*88mm/22*3*3.4inch
Material: Extruded Aluminum Profile, High transmission PC Lens
Mounting Bracket: Aluminum Side Mounting Bracket (120 Degree Adjustable)
Package Included:
1x 120W PHILIPS LED light bar
With necessary mounting brackets
LED Tailgate light bar 60in (Led trang trí chuyên cho bán tải)
If you’re looking for a top rated LED tailgate light bar to make your ride stand out from the others, this could be it. The Recon has scanning amber turn signals, red running, hazard, and brake lights, and white reverse lights. I was unable to find out if it was waterproof, but if installed right and sealed tight, water and moisture should not be able to get in.
Thu gọn
The plug and play feature is easy and will get your tailgate bar up and running in a matter of minutes. If you want to take the extra time to ensure everything is going to work the way it should, you can also choose to hardwire it into virtually any car, pickup truck, or SUV, as long as the measurements are correct. This LED tailgate light bar is SAE and DOT approved for use, the only one to have these certifications on the list as far as I can tell. This would definitely make me feel better about using them since some of the lights found on vehicles are not street legal. The only colored lights I want to see in my rearview mirror are the ones from my buddies truck, not the five-o.
Length: 60 inches
60INCH LED Tailgate light bar
Led trang trí chuyên dùng cho bán tải
KT: 60in
