SYSTEM CONFIGURATION 7.1-Channel Home Theater Receiver HT-R980 7.1-Channel Home Theater Speaker System HTP-980
GENERAL SPECIFICATIONS A/V RECEIVER 130 W/Ch at 6 Ohms, 1 kHz, 1 Channel Driven, IEC Frequency Response: 5 Hz–100 kHz/+1 dB, -3 dB (DSP bypass) WHD: 435 x 151.5 x 328.5 mm Weight: 9.6 kg SPEAKER SYSTEM Front Speaker Max. Input Power: 130 W Impedance: 8 Ohms Frequency Response: 50 Hz–45 kHz WHD: 158 x 433 x 199 mm Weight: 5.3 kg Center Speaker Max. Input Power: 130 W Impedance: 8 Ohms Frequency Response: 50 Hz–45 kHz WHD: 433 x 158 x 199 mm Weight: 5.3 kg Surround Speaker Max. Input Power: 130 W Impedance: 8 Ohms Frequency Response: 50 Hz–45 kHz WHD: 200 x 275 x 169 mm Weight: 3.5 kg Surround Back Speaker (HT-S9300THX Only) Max. Input Power: 130 W Impedance: 8 Ohms Frequency Response: 50 Hz–45 kHz WHD: 200 x 275 x 169 mm Weight: 3.5 kg Subwoofer Rated Output Power: 125 W Minimum Continuous Power (6 Ohms, 100 Hz, Maximum 1% THD) Frequency Response: 20 Hz–100 Hz WHD: 380 x 444 x 429 mm Weight: 15.5 kg
