4.070
8.591
Sàigòn
Còn đây là quy định của nước ngoài, đọc mà ngẫm nè:
STATUTORY SPEED LIMITS
Statutory speed limits are established by State legislatures for specific types of roads (e.g., Interstates, rural highways, urban streets) and can vary from State to State. They are enforceable by law and are applicable even if the speed limit sign is not posted. Examples of statutory speed limits include:
25 mph in residential or school districts,
55 mph on rural highways, and
70 mph on rural Interstate highways.
POSTED SPEED LIMIT
Posted speed limits (sometimes called regulatory speed limits) are those that are sign-posted along the road and are enforceable by law. A posted speed limit could be the same as the statutory speed set by the State legislature, or it could be established by a city, county, or State transportation agency as an adjustment to the statutory speed limit. Some cities and counties will establish a blanket speed limit for roads in their jurisdictions. Those limits are generally posted at the city limits or county lines. The posted speed limit can differ from the statutory speed limit; in these cases, the posted speed limit is determined using an engineering speed study and takes priority over the established statutory speed limit.
Statutory SL là điều 6,7,8 TT31, còn Posted SL là P127 đóa!
4.070
8.591
Sàigòn
Còn đây của NSW:
Speed limits
- On roads where there’s a speed limit sign, you must not drive faster than that speed limit.
- On roads where there’s no speed limit sign, you must not drive faster than the default speed limit:
+ 50km/h in ‘built-up areas’ – areas with street lights and buildings next to the road less than 100m apart
+ 100 km/h for all other roads.
4.070
8.591
Sàigòn
Còn UK nè:
A speed limit of 30 miles per hour (48km/h) applies to all single and dual carriageways with street lights, unless there are signs showing otherwise.
4.070
8.591
Sàigòn
Speed Limit của EU, luôn luôn có câu "unless otherwise stated by traffic signs":
Ví dụ Belgium:
Standard speed limits (unless otherwise stated by traffic signs) [km/h]
70: Outside urban areas in the Flemish Region; On public roads with two or more lanes in each direction, separated by road markings, and on the other public roads.
90: Outside urban areas in Wallonia and Brussels; On public roads with two or more lanes in each direction, separated by road markings, and on the other public roads.
120: Motorways and roads with two or more lanes in each direction, not separated by road markings.
8.588
7.342
Trả lời lại cho mày (gói gọn trong P127 và R420 cho gọn thôi nhé, đừng bắt bẻ)
- Gặp P127: tuân thủ con số (ghi trên P127) theo điều 4.1 TT31.
Tào lao, tự suy diễn, câu nào trong điều 4.1 ghi là phải tuân thủ con số ghi trên P127, trích dẫn ra nhé, đừng phán ngu như vậy hoài.
- Gặp R420: tùy vị trí, tùy loại phương tiện mà tham chiếu vô điều 6 của TT31 để tìm ra (cũng 1 con số, và tuân thủ con số này)
Có gì khó hiểu đâu mà sao mày ko hiểu nổi?
À, giải thích thêm cho mày chứ chắc là mày ko hiểu: "tuân thủ con số" ý là "không được chạy tốc độ vượt quá con số ghi trên biển", "con số" trong R420 cũng vậy, là con số tham chiếu cho loại xe trên vị trí lưu thông cụ thể...
Má ơi, kỹ năng đọc hiểu quá kém.
Quy định về tốc độ không phải là tốc độ quy định nhé thằng ngu.
Tiếng Việt đọc không hiểu mà cứ cãi cùn cãi bậy,
8.588
7.342
Tại mày hiểu điều 4 NGU thôi. nhắc lại:
- 4.1 Gặp biển báo (P127 là một trong số đó): tuân thủ hiệu lệnh của biển
- 4.2 Không có biển báo: tuân thủ điều 6, 7... của thông tư 31.
Quay lạy #393 học lại đi!
Lại tự phán, éo dẫn được câu nào của điều 4.1 TT 31 ghi như vậy mà cứ phán.
4.1 nói về con số ghi trên biển báo là của khoảng cách an toàn nhé thằng NGU.
Còn về tốc độ thì phải tuân thủ QUY ĐỊNH về TỐC ĐỘ.
Nhắc lại lần nữa QUY ĐỊNH về TỐC ĐỘ là nằm trong Điều 6, 7,8,9 của CHƯƠNG II Thông tư 31 nhé.
Quy định về tốc độ bao gồm tất cả các suy định trong các điều kể trên, KHÔNG PHẢI là Tốc độ quy định hay tốc độ hạn chế trên p127 nhé THẰNG NGU.
8.588
7.342
Sao mày không tự suy ngẫm, nếu nhà làm luật muốn quy định như ý mày thì sao họ không quy định luôn là
- Khi gặp biển báokhông gặp biển báo đều phải tuân thủ theo quy định tại điều 6,7, 8, 9 và Điều 11 của TT này.
mắc chi quy định 4.1 tách ra khỏi 4.2? chỉ cần tách cái vụ khoảng cách ra riêng thôi!
Ủa nhà làm luật có ý của họ, nhắc cho mày nhớ Chủ đề của Thông tư 31 này là QUY ĐỊNH về TỐC ĐỘ và khoảng cách an. toàn.
Tiêu đề của Điều 4 là ...Nguyên tắc chấp hành QUY ĐỊNH về TỐC ĐỘ ....
Chương II của TT31 này cụ thể chi tiết các QUY ĐỊNH về TỐC ĐỘ...qua các điều 6,7,8 9...
Cho nên 4.1 nêu rõ là phải tuân thủ QUY ĐỊNH về TỐC ĐỘ. Không hề có câu nào như suy diễn của mày là theo P127 nhé.
Hiểu chưa thằng NGU.
8.588
7.342
Má ơi, lại còn đòi P127 ghi các quy định tốc độ của điều 6,7,8 nữa?
- P127 thuộc phần 4.1
- Điều 6,7,8 thuộc phần 4.2
Khi không nằm trong 4.1 thì tìm trong 4.2, khi đã thuộc phạm vi 4.1 rồi thì theo 4.1 mà xử.
Cái này hình như nói rồi.
Cả hai (biển P127 và các quy định tại điều 6, 7 của TT31) ĐỀU quy định về "tốc độ tối đa cho phép" . Nếu như mày nói "P127" không phải "quy định về tốc độ" thì điều 6, 7 cũng không.
Còn quy định về "Tốc độ tối đa cho phép" đây nè:
Tốc độ tối đa cho phép là tốc độ lớn nhất trên một tuyến đường, đoạn đường hoặc làn đường được cấp có thẩm quyền quy định. Người điều khiển phương tiện không được phép vận hành xe ở tốc độ cao hơn.
Dốt mà cứ thích so đo câu chữ!
Mày tự suy diễn và tự phán NGU chứ làm gì có câu nào trong TT cho là P127 thuộc 4 1.
Trích dẫn cho cụ thể, không phán nhé thằng NGU
