495
RE: Xe này cổ 61 sao mà mới wá
pé này bán đấu giá dc cả triệu đô ah bác ah.
178
33
Xe này của diễn viên điện ảnh, vừa đấu giá xong. Các bác đoán xem bi nhiêu cái thằng Mỹ.
1.251
Các bác làm em khủng hoảng luôn, nhưng nhìn chất độ là biết không phải của VN rồi.
178
33
Có bác nào biết lý lịch em này. Post bài cho anh em s1ng tầm với.
250 GT Spyder California SWB
Replacing their LWB California Spyder with a SWB version, Scaglietti showed a new Spyder California at Geneva in 1960. Based on the 250 GT SWB, it also introduced disc brakes and a 280 hp (209 kW) version of the 250 V12. About 55 were built. A replica of the 250 GT Spyder California called the "Modena" was featured as the untouchable car owned by Cameron Frye's dad in the teen movie, Ferris Bueller's Day Off.
On May 18, 2008, a pristine 250 SWB California Spyder previously owned by James Coburn was bought at auction for 7.04 million euros (GB£5M) by British TV and radio presenter Chris Evans.
related cars 1956 Ferrari 250 GT Tour de France
submitted by Richard Owen
production years 1958 - 1963
coachbuilder Scaglietti
production 125
engine Type 168 60º V 12
position Front Longitudinal
aspiration Natural
block material Aluminum Alloy
valvetrain SOHC, 2 Valves per Cyl
fuel feed 3 40 DCL6 Weber Carburetors
displacement 2953 cc / 180.2 cu in
bore 73 mm / 2.87 in
stroke 58.8 mm / 2.31 in
compression 9.2:1
power 208.8 kw / 280 bhp @ 7000 rpm
specific output 94.82 bhp per litre
bhp/weight 203.05 bhp per tonne
torque 273.9 nm / 202 ft lbs @ 5500 rpm
body / frame Steel Body over Tubular Steel Chassis
driven wheels RWD
wheel type Borrani Wire
front tires 6.0x16
rear tires 6.0x16
front brakes Dunlop Discs
rear brakes Dunlop Discs
steering Worm & Sector
f suspension Unequal Wishbones w/Coil Springs, Anti-Roll Bar
r suspension Rigid Axle w/Semi Elliptic Leaf Springs, Radius Arms
weight 1379 kg / 3040 lbs
wheelbase 2400 mm / 94.5 in
front track 1378 mm / 54.3 in
rear track 1374 mm / 54.1 in
length 4200 mm / 165.4 in
width 1720 mm / 67.7 in
height 1370 mm / 53.9 in
transmission 4-Speed Manual
gear ratios 2.54:1, 1.70:1, 1.26:1, 1.00:1
final drive 4.86:1
top speed 233.4 kph / 145 mph
0 - 60 mph 6.5 seconds
495
bác Vincent đúng là ko hổ danh hạng E
178
33
Chiếc sport 8 máy của công tử Bạc liêu từng chở cô ba Trà ( Đại thế giới) bây giờ ở đâu ta ?
