CODE nó đây
Code Model Description / Probable Cause
12
Camry Corolla RPM Signal / Distributor or Circuit, ECM
13 Camry Corolla RPM Signal / Distributor or Circuit, ECM
14 Camry Corolla Ignition Signal / Ignitor or Circuit to ECM. ECM
16(1.8L) Corolla Electronic
Controlled A/T
Signal / ECM or Circuit
21(2.2L)
Camry Corolla HO2S Sensor
Signal / O2 Sensor or Circuit, ECM
21(3.0L) Camry HO2S Sensor
Signal / Left O2 Sensor or Circuit, ECM
22 Camry Corolla Coolant Temp.
Sensor (CTS)Signal / Coolant Temp. Sensor or Circuit, ECM
24
Camry Corolla Intake Air
Temp. (IAT) Sensor
Signal / Intake Air Temp. Sensor or Circuit, ECM
25 Camry Corolla Lean Air/Fuel
Mixture / Loose Ground, Injector or Circuit, Fuel Pressure, Ignition
System, Coolant Temp. Sensor (CTS),Airflow Meter (MAF),
Vacuum Sensor (MAP), HO2s Sensor or Circuit, CompressionPressure, ECM
26
Camry Corolla Rich Air/Fuel
Cold Start Injector
or Circuit,CompressionPressure, ECM
27 Camry Corolla Sub-O2 Sensor
Signal / Sub-O2 Sensor or Circuit, ECM
28(3.0L) Camry Right HO2S
Sensor Signal /
Right O2 Sensor or Circuit, ECMl
31(2.2L) Camry Corolla Vacuum Sensor (MAP)
Signal / Vacuum Sensor or Circuit, ECM
31(3.0L) Camry Airflow Meter (MAF) / Airflow Meter or Circuit, ECM
32(3.0L) Camry Airflow Airflow Meter (MAF) /
Airflow Meter or Circuit, ECMMeter
41 Camry Corolla TPS Signal / Throttle Position Sensor or Circuit, ECM
42 Camry Corolla Vehicle Speed
Sensor (VSS) Signal / Vehicle Speed Sensor or Circuit, ECM
43(2.2L) Camry Corolla Starter Signal / Starter Signal Circuit, Main Relay,
Ignition Switch or Circuit,
ECM
43(3.0L) Camry Starter Signal / Starter Signal Circuit, Main Relay, Ignition Switch
or Circuit,
ECM
51 Camry Corolla Switch / A/C Switch, Park/Neutral Switch or Circuit, TPS or Circuit
52(2.2L) Camry Corolla(1.8L) Knock Sensor
Signal / Knock Sensor or Circuit, ECM
52(3.0L) Camry Left Knock
Sensor Signal / Knock Sensor or Circuit, ECM
53(3.0L) Camry Knock Control
Signal / ECM
55(3.0L) Camry Right Knock Sensor Signal / Knock Sensor or Circuit, ECM
71 Camry Corolla EGR System
Malfunction / EGR System, EGR Temp. Sensor or Circuit, EGR-VSV,
ECM
