3.302
1.159
SaiGon
Cái này chứ ko phải cái kia
Toyota Generic Trouble Codes​
(Codes Apply to Most Toyota Models – See Table at the Bottom of the Page for Model Specific Codes)
[xtable=border:2|cellpadding:6|54%x@]
{tbody}
{tr}
{th=colspan:2|@x31}OBD1 Codes{/th}
{/tr}
{tr}
{td=6%x@}1{/td}
{td=94%x@}Normal Condition.{/td}
{/tr}
{tr}
{td=6%x@}2{/td}
{td=94%x@}Air Flow Meter signal.{/td}
{/tr}
{tr}
{td=6%x@}3{/td}
{td=94%x@}Ignition signal.{/td}
{/tr}
{tr}
{td=6%x@}4{/td}
{td=94%x@}Engine Coolant Temperature Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}5{/td}
{td=94%x@}Oxygen Sensor.{/td}
{/tr}
{tr}
{td=6%x@}6{/td}
{td=94%x@}RPM signal (Crank Angle Pulse).{/td}
{/tr}
{tr}
{td=6%x@}7{/td}
{td=94%x@}Throttle Position Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}8{/td}
{td=94%x@}Intake Air Temperature Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}9{/td}
{td=94%x@}Vehicle Speed Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}10{/td}
{td=94%x@}Starter signal.{/td}
{/tr}
{tr}
{td=6%x@}11{/td}
{td=94%x@}Switch signal.{/td}
{/tr}
{tr}
{td=6%x@}11{/td}
{td=94%x@}ECU/ECM.{/td}
{/tr}
{tr}
{td=6%x@}12{/td}
{td=94%x@}Knock Control Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}12{/td}
{td=94%x@}RPM signal.{/td}
{/tr}
{tr}
{td=6%x@}13{/td}
{td=94%x@}Knock Control CPU (ECM).{/td}
{/tr}
{tr}
{td=6%x@}13{/td}
{/tr}
{tr}
{td=6%x@}14{/td}
{td=94%x@}Turbocharger Pressure.{/td}
{/tr}
{tr}
{td=6%x@}14{/td}
{/tr}
{tr}
{td=6%x@}21{/td}
{/tr}
{tr}
{td=6%x@}22{/td}
{/tr}
{tr}
{td=6%x@}23{/td}
{/tr}
{tr}
{td=6%x@}24{/td}
{/tr}
{tr}
{td=6%x@}25{/td}
{td=94%x@}Air-Fuel Ratio Lean.{/td}
{/tr}
{tr}
{td=6%x@}26{/td}
{td=94%x@}Air-Fuel Ratio Rich.{/td}
{/tr}
{tr}
{td=6%x@}27{/td}
{td=94%x@}Sub Oxygen Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}28{/td}
{td=94%x@}No. 2 Oxygen Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}31{/td}
{td=94%x@}Air Flow Meter signal (Vacuum Sensor signal).{/td}
{/tr}
{tr}
{td=6%x@}32{/td}
{/tr}
{tr}
{td=6%x@}34{/td}
{td=94%x@}Turbocharger Pressure signal.{/td}
{/tr}
{tr}
{td=6%x@}35{/td}
{td=94%x@}Turbocharger Pressure Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}35{/td}
{td=94%x@}HAC Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}41{/td}
{/tr}
{tr}
{td=6%x@}42{/td}
{/tr}
{tr}
{td=6%x@}43{/td}
{/tr}
{tr}
{td=6%x@}51{/td}
{/tr}
{tr}
{td=6%x@}52{/td}
{td=94%x@}Knock Sensor signal.{/td}
{/tr}
{tr}
{td=6%x@}53{/td}
{/tr}
{tr}
{td=6%x@}54{/td}
{td=94%x@}Inter-cooler ECM signal.{/td}
{/tr}
{tr}
{td=6%x@}71{/td}
{td=94%x@}EGR System.{/td}
{/tr}
{tr}
{td=6%x@}72{/td}
{td=94%x@}Fuel Cut Solenoid signal.{/td}
{/tr}
{tr}
{td=6%x@}78{/td}
{td=94%x@}Fuel Pump Control signal.{/td}
{/tr}
{tr}
{td=6%x@}81{/td}
{td=94%x@}TCM Communication.{/td}
{/tr}
{tr}
{td=6%x24}83{/td}
{td=94%x24}TCM Communication.{/td}
{/tr}
{tr}
{td=6%x@}84{/td}
{/tr}
{tr}
{td=6%x@}85{/td}
{/td}
{/tr}
{/tbody}
[/xtable]​
9.925
31.266
Q3
nghe nói remove dây xanh dương chân 11 ECU ra là khỏi check engine , nối đèn check engine vào đèn bình nhớt , bat công tắc nó sáng , đề máy nổ cái tắt 1 lượt với đèn nhớt luôn , vn số 1 !!!!!!!!
Chú ý mua xe cũ chiêu này lái hay tin dùng để gạt anh e ta
Đèn Check Engine phải độc lập với đèn nhớt nha
biết xe thì .....giựt dây sensor nhớt ra, đèn Check tắt ngúm theo là hiểu , lái sẽ kêu mình là sư tổ
có khi nối luôn đèn ABS nữa - máy chạy cả đám tắt ngóm, anh thay xe ngon chưa ạ
3.302
1.159
SaiGon
Cảm ơn bác CÒ
lưu cái link
http://www.ebay.com/itm/ELM327-v1-5...1180321092&pt=Motors_Automotive_Tools&vxp=mtr
3.302
1.159
SaiGon
CT zìa rùi, bàn giao thớt cho CT đấy, em đi zìa Xì Phố đây, hết giờ làm rùi
