Để nguyên con mai mốt bán xác cho khỏe người mua bác. Chỉ việc lái xe đi khỏi phải cẩu kéo chi cho mệtCòn kg biết tháo ra bán đồ món...kaka
Nè lão Liêm, khoe hoài àSố khung xe E nè 4T1SK13E2NU000058 .Bác 95LE Check thử phải chín he đời đầu hôn!
1992 Toyota Camry XLE
- General
- Equipment
- Colors
- Recalls
{tbody}
{tr}
{td}VIN{/td}
{td}4T1SK13E2NU000058{/td}
{td}Vehicle Accidents/Service{/td}
{td}Get Vehicle History Report NOW{/td}
{/tr}
{tr}
{td}Year{/td}
{td}1992{/td}
{td}Engine Type{/td}
{td}2.2L L4 DOHC 16V{/td}
{/tr}
{tr}
{td}Make{/td}
{td}Toyota{/td}
{td}Driveline{/td}
{td}FWD{/td}
{/tr}
{tr}
{td}Model{/td}
{td}Camry{/td}
{td}Ground Clearance{/td}
{td}No data in.{/td}
{/tr}
{tr}
{td}Trim Level{/td}
{td}XLE{/td}
{td}Front Brake Type{/td}
{td}Disc{/td}
{/tr}
{tr}
{td}Manufactured In{/td}
{td}UNITED STATES{/td}
{td}Rear Brake Type{/td}
{td}Drum{/td}
{/tr}
{tr}
{td}Body Style{/td}
{td}SEDAN 4-DR{/td}
{td}Anti-Brake System{/td}
{td}Non-ABS or
4-Wheel ABS{/td}
{/tr}
{tr}
{td}Transmission{/td}
{td}4-Speed Automatic Overdrive{/td}
{td}Standard Seating{/td}
{td}5{/td}
{/tr}
{tr}
{td}MPG Hwy{/td}
{td}27 miles/gallon{/td}
{td}Optional Seating{/td}
{td}No data{/td}
{/tr}
{tr}
{td}MPG City{/td}
{td}21 miles/gallon{/td}
{td}Tires{/td}
{td}195/70HR14{/td}
{/tr}
{tr}
{td}Dealer Invoice{/td}
{td}No data USD{/td}
{td}Wheelbase{/td}
{td}103.10 in.{/td}
{/tr}
{tr}
{td}MSRP{/td}
{td}$19,428 USD{/td}
{td}Curb Weight{/td}
{td}3098 lbs{/td}
{/tr}
{/tbody}
[/xtable]
- General
- Equipment
- Colors
- Recalls
[xtable=skin1|cellpadding:5|cellspacing:0|93%x@]
{tbody}
{tr}
{td}VIN{/td}
{/tr}
{tr}
{td}Year{/td}
{td}1992{/td}
{/tr}
{tr}
{td}Make{/td}
{td}Toyota{/td}
{td}Driveline{/td}
{td}FWD{/td}
{/tr}
{tr}
{td}Model{/td}
{td}Camry{/td}
{/tr}
{tr}
{td}Trim Level{/td}
{td}XLE{/td}
{td}Disc{/td}
{/tr}
{tr}
{td}Drum{/td}
{/tr}
{tr}
{td}Body Style{/td}
{td}SEDAN 4-DR{/td}
{td}Non-ABS or
4-Wheel ABS{/td}
{/tr}
{tr}
{td}5{/td}
{/tr}
{tr}
{td}MPG Hwy{/td}
{td}No data{/td}
{/tr}
{tr}
{td}MPG City{/td}
{td}Tires{/td}
{td}195/70HR14{/td}
{/tr}
{tr}
{td}Wheelbase{/td}
{td}103.10 in.{/td}
{/tr}
{tr}
{td}MSRP{/td}
{td}3098 lbs{/td}
{/tr}
{/tbody}
[/xtable]
Thua me gở bài cào, thua XLE gở lại năm sản xuất, he he
1995 Toyota Camry LE
[xtable=cellpadding:5|cellspacing:0|93%x@]
{tbody}
{tr}
{td}VIN{/td}
{td}4T1SK12E3SU539835{/td}
{/tr}
{tr}
{td}Year{/td}
{td}1995{/td}
{/tr}
{tr}
{td}Make{/td}
{td}Toyota{/td}
{td}Driveline{/td}
{td}FWD{/td}
{/tr}
{tr}
{td}Model{/td}
{td}Camry{/td}
{/tr}
{tr}
{td}Trim Level{/td}
{td}LE{/td}
{td}Disc{/td}
{/tr}
{tr}
{td}Drum{/td}
{/tr}
{tr}
{td}Body Style{/td}
{td}SEDAN 4-DR{/td}
{td}Non-ABS or
4-Wheel ABS{/td}
{/tr}
{tr}
{td}5{/td}
{/tr}
{tr}
{td}MPG Hwy{/td}
{td}28 miles/gallon{/td}
{td}No data{/td}
{/tr}
{tr}
{td}MPG City{/td}
{td}Tires{/td}
{td}195/70R14{/td}
{/tr}
{tr}
{td}Wheelbase{/td}
{td}103.10 in.{/td}
{/tr}
{tr}
{td}MSRP{/td}
{td}$19,778 USD{/td}
{td}3086 lbs{/td}
{/tr}
{/tbody}
[/xtable]
[xtable=cellpadding:5|cellspacing:0]
{tbody}
{tr}
{td}Trim Level{/td}
{td}LE{/td}
{td}Manufactured in{/td}
{/tr}
{tr}
{td}Body Style{/td}
{td}SEDAN 4-DR{/td}
{/tr}
{tr}
{td}Driveline{/td}
{td}FWD{/td}
{td}Tank{/td}
{td}18.50 gallon{/td}
{/tr}
{tr}
{td}City MPG{/td}
{td}Highway MPG{/td}
{/tr}
{tr}
{td}Non-ABS | 4-Wheel ABS{/td}
{td}Steering Type{/td}
{td}R&P{/td}
{/tr}
{tr}
{td}Disc{/td}
{td}Drum{/td}
{/tr}
{tr}
{td}Turning Diameter{/td}
{td}35.40 in.{/td}
{td}Front Suspension{/td}
{td}Ind{/td}
{/tr}
{tr}
{td}Rear Suspension{/td}
{td}Ind{/td}
{td}Front Spring Type{/td}
{td}Coil{/td}
{/tr}
{tr}
{td}Rear Spring Type{/td}
{td}Coil{/td}
{td}Tires{/td}
{td}195/70R14{/td}
{/tr}
{tr}
{td}Front Headroom{/td}
{td}38.40 in.{/td}
{td}Rear Headroom{/td}
{td}37.10 in.{/td}
{/tr}
{tr}
{td}Front Legroom{/td}
{td}43.50 in.{/td}
{td}Rear Legroom{/td}
{td}35.00 in.{/td}
{/tr}
{tr}
{td}Front Shoulder Room{/td}
{td}56.80 in.{/td}
{td}Rear Shoulder Room{/td}
{td}56.10 in.{/td}
{/tr}
{tr}
{td}Front Hip Room{/td}
{td}55.90 in.{/td}
{td}Rear Hip Room{/td}
{td}55.40 in.{/td}
{/tr}
{tr}
{td}3086 lbs{/td}
{td}—{/td}
{/tr}
{tr}
{td}Overall Length{/td}
{td}187.80 in.{/td}
{td}Overall Width{/td}
{td}69.70 in.{/td}
{/tr}
{tr}
{td}Overall Height{/td}
{td}55.10 in.{/td}
{td}Wheelbase{/td}
{td}103.10 in.{/td}
{/tr}
{tr}
{td}—{/td}
{td}Track Front{/td}
{td}61.00 in.{/td}
{/tr}
{tr}
{td}Track Rear{/td}
{td}59.00 in.{/td}
{td}Cargo Length{/td}
{td}—{/td}
{/tr}
{tr}
{td}Width at Wheelwell{/td}
{td}—{/td}
{td}Width at Wall{/td}
{td}—{/td}
{/tr}
{tr}
{td}Depth{/td}
{td}—{/td}
{td}5{/td}
{/tr}
{/tbody}
[/xtable]
Bên BB có một ổ bánh mỳ dưới 200 củ kìa
Đừng làm mềnh điên lên là mềnh đổi bầu đấy.
Bánh mỳ ngon hơn hộp quẹt mừ bác, bán hộp quẹt mua bánh mì về nướng....$ tiếp đi CT ơi, . Sánh giờ bận quá, thôi em chờ bác Trình vài hôm nữa, nếu không xong thì phiền Bác Nghĩa một chuyến nhé, cảm ơn bác nhiều.Dạo này người ta hỏng xài 87-91 nữa hay sao ấy...
Nếu là nữ thì quan hệ được hử Bác? còn nam thì sao ạ?Xem nick kg biết bác là nam hay nữ ạh? Biết để tiện việc quan hệ, trao đổi
Quan hệ gì..pa?Xem nick kg biết bác là nam hay nữ ạh? Biết để tiện việc quan hệ, trao đổi
Bác Trung chú ý nè, tắt hết công tắc điện máy lạnh, quạt.Biết chết liền. Hic
chuẩn bị tháo cái gim giấy ra, xếp lại hình chữ V, dỡ nắp capo lên, tìm cái hộp nhựa kế bên phuộc phải dỡ nắp ra, tìm TE1 và E1 giống vậy nè
cắm ghim V vào nha
Ngồi vào Cabin bật công tắc nhìn đèn Engine check chớp
chớp 2 lần, mỗi lần bao nhiêu nhịp ngồi đếm
http://www.troublecodes.net/toyota/
Chẹp chẹp, ực ực :3danbanh:Cái tấm cách âm, chóng nóng capo tại Cam bú chia là 30 Obama View attachment 78671 zin như cục pin luôn.
Còn cái vụ nút gạt , bấm máy lạnh thì E có 1 con LE , 1 con XLE . Bấm gạt gì cũng có ah. Bác úp hình lên mới biết ah!
Hướng dẫn ko phải tiếng Nhật đâu nè
NOTE: Not all trouble codes will activate MIL (CHECK ENGINE light)
RETRIEVING CODES for vehicles before 96
- Before proceeding, make sure the:
- CHECK ENGINE light circuit is functional. It should be ON when the ignition switch is ON with the engine stopped.
- Battery voltage is above 11 volts.
- Throttle valve is fully closed (Throttle Position Sensor IDL points closed).
- Accessory switches (A/C, etc.) are OFF.
- Engine is at normal operating temperature (if possible).
- Turn ignition switch to ON position.
- Do not start the engine. ko đề nha
- Place a jumper wire across TEl and El terminals in engine check connector.
- Count number of flashes from CHECK ENGINE light.
- If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuouslyand evenly about 2 times a second.
- Otherwise, the light will blink a number of times equal to the trouble code as follows:
- The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
- The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
- If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
- Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
- The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected.
- When finished, remove the jumper wire.
- After repairing the malfunction, clear the codes from the ECUs memory.
