1.270
55
Vĩnh Nam nói:
Hãng khuyến cáo là không nên dùng số N khi lưu thông và cả khi ngừng xe vì sẽ gây hại đến hộp số tự động, chỉ dùng số N khi kéo xe.
xl mình nghi ngờ trình độ và khả năng của bạn
1.945
11.442
em nghĩ là: ko nên về N khi đang lăn bánh vì động cơ sẽ ko truyền tải điện đến bánh xe dẫn đến các chức năng an toàn bị vô hiệu hoá --> khả năng xảy ra tai nạn
còn nếu đã dừng hẳn thì về N vô tư đi
1.270
55
Hi, Ferman!
I recently bought a Toyota Vios 1.5 equipped with a four-speed automatic transmission. I have a habit of shifting to neutral during stop-and-go traffic conditions and while waiting for the light to go green.
My question is: will this have a bad effect on my transmission? I feel like leaving the gear set to D during traffic consumes more fuel and might place additional stress on the brakes because it is trying to stop the car constantly. Is this true as well?
I used to drive a Lancer 1.6 equipped with CVT. I never really had a problem with the transmission despite doing the same thing. But I've read that CVT is different from a traditional automatic transmission, which the Vios has. I'm really wondering if this driving habit is good for my car or not.
Thank you very much for reading this letter.
Regards,
Dennis
Hi Dennis,
What you are doing is correct.
Quite a number of drivers, particularly the ones who picked up bad driving habits from other drivers who didn't know any better, often practice improper driving by not shifting to neutral when the car is not moving. While I would like to tell you that there is a good reason (under normal circumstances) for keeping it in D and stepping on the brakes at a stop, I can't. It's mostly born out of laziness and improper training.
As you have correctly surmised, the engine does consume more fuel and you do wear down your brake-system components more when you leave your transmission in D or Drive while the traffic light is red or when you’re idling and waiting.
With automatic transmissions, the engine is energizing or driving the transmission to move in the direction of the gear you've selected--forward or reverse. When you keep it in gear, you are telling your vehicle to move; when you're on the brakes, you're preventing motion. You're unnecessarily and slowly raising your automatic transmission fluid, wearing out your transmission clutches, and consuming more fuel because you're on the brakes to keep the car from inching forward. You're also unnecessarily wearing down and heating up your brake pads. By simply shifting to N or neutral there would be no need to apply the brakes with the amount of force required to resist forward motion.
If you notice all of the above result in unnecessary wear, all of which increase the cost of operating and maintaining your vehicle. It's also a very unsafe practice as if you happen to accidentally lift your foot off the brake, you will most likely get into an accident.
While we're on the subject of automatic transmissions, it is also a very bad habit to shift into P or Park when you're at a stoplight. Numerous drivers have adopted the practice as well and, quite frankly, it is also an accident waiting to happen apart from slowing damaging a different part of your transmission, which will eventually lead to the a different sort of automatic transmission failure.
It won't matter if your car has CVT or the conventional multi-speed automatic transmission. Shifting to neutral under most normal conditions is good practice.
Best regards,
Ferman Lao
Tech editor
http://www.topgear.com.ph...-when-stuck-in-traffic
9.912
2.760
Manual nó ghi rõ mà vẫn cứ tranh cãi, chắc bọn sản xuất nó đầu lâu rồi.
1.270
55
dawmgoodman ® nói:
manual dành cho xe điện mà
Vĩnh Nam nói:
hainam261 nói:
em vẫn chưa hiểu dừng đèn đỏ lâu chuyển N, đạp thắng mà cũng có hại sao ta :(
Đây là HDSD từ nhà sản xuất
9/12/12
155
44
con Altis thần thánh nhà tôi xài hộp số CVT nên chắc dừng đèn đỏ trả về N khi đỏ hơn 15 giấy chắc k thành vấn đề các anh nhỉ?
9.912
2.760
Quách Bạch Long.* nói:
CVT có số k nhỉ?
1.270
55
anh Newbie SG nói thế này
Newbie_SG nói:
Chán các anh mẹc quá, học hành chưa quá lớp 8 có khác. Đọc HDSD bằng tiếng Việt còn không hiểu mà cũng đòi lái xe & bán xe. Có anh còn đòi lái cả MBBG nữa... Thiệt là vãi đạn.
Xe còn lăn bánh thì không được dùng N.
Xe dừng hẳn thì về N vô tư.
Anh nào kéo xe mấy chục km tại số N thì phải nói là quá ngu luôn. Phải gác bánh chủ động lên xe cứu hộ mà kéo chứ.
Khi xe dừng, máy nổ cầm chừng, sinh công không đáng kể, để D hay N thì cũng chỉ là trượt dầu trong bộ torque converter của hộp số AT, ở D, công đó triệt tiêu bằng phanh nhẹ cũng hết.
Các nấc số AT chỉ là đóng mở các van dầu hộp số, đưa về N thì mất thêm một số lần đóng mở van dầu thôi, hỏng sao được.
Reactions: phuchoadong
519
Phi thạch nói:
Newbie_SG nói:
Á đù. Kinh lật xư thặc :D
