XTC
97
Hà Nội
LeMinhKhoi nói:
Bác giups mình với. Nếu được bác gửi bản đầy đủ cho mình vào để mình ngâm cứu với ạ. Tks Bác nhiều
KNAFW411BA5144323
Cụ dịch được dòng này không ạ, nếu không thì để lại mail nhé cụ:
KNAFW411BA5144323CERATO/FORTE/CERATO KOUP/SHUMA KOUP 08MYVIETNAM2009/09/308A26ATDS4D261BH24703 Search Model NoTDS4D261BEngine NoG4FC9H308762T/M NoTDF 144323KGENPTD08CERATO/FORTE/CERATO KOUP/SHUMA KOUP 08MYEngine MIP T/M MIP Exterior Color IY / IY (IY)Interior ColorWKDRIVE TYPEDRIVE TYPE - LHDWEATHER TYPEWEATHER - THE TROPICAL ZONEBODY TYPESEDAN - 4DR 5PENGINE CAPACITY1600 CC - GAMMAENGINE TYPEDOHC - MPIFUEL TYPEGASOLINE - UNLEADEDTRANSAXLEAUTO - 4 SPEED 2WD
FULL AUDIO OPTION STANDARD OPTIONOPTIONAL OPTION Code
Description
0091A4ENGINE PACKAGE - CVVT ENG0094A2COLOR PACKAGE - TYPE 22843A3EVAP. GAS CONTROL - ULEV2861A2MUFFLER MAIN ASSY - SINGLE-CR COAT`G2921A2ENGINE COVER - SEMI3111B2FUEL TANK-CAPACITY - 52 LITER3281A2PEDAL TYPE - AL PAD3711A4BATTERY CAPACITY - 45AH (20HR)371CA1BATTERY SAVER3921A2SENSOR-AIR FLOWER - SPEED DENSITY4371C2AT KNOB - LEATHER WRAPPED+CR COAT`G4509A3GATE TYPE H-MATIC5291VAAL WHEEL 7.0J * 17 - A TYPE5293G1215 TIRE - 215/45 R175296C1FULL SIZE WHL COVER - A TYPE5297A3FULL SIZE 1EA - AL WHEEL & TIRE529AB1TIRE PRESSURE LABEL - EUROPE529TA7TOOL SET & JACK LABEL - EUROPE5411A1FR SUSP TYPE - MACPH. W/COIL SPRING5412A2S/ABSORBER TYPE - GAS5511A9RR SUSP TYPE - TORSION AXLE5512A2S/ABSORBER TYPE - GAS5611B33-SPOKE - LEATHER5631A3STEER`G COLUMN-MANUAL LWR TILT5691A3DRIVER SIDE - DEPOWERED5711A2HPS(HYDRAULIC POWER STRG)5811A4FR BRAKE - DISC-15 INCH5812A7RR BRAKE - DISC-14 INCH5891A2ABS (ANTI LOCK BRK SYS)5911A3SINGLE BOOSTER - 10 INCH5972A1P/BRAKE KNOB TRIM - SOFT PVC5973A3P/BRAKE PUSH BUTTON TRIM - CR COAT`G6501A1HIGH GRADE811AA1HOOD INSULATOR8123A2TRUNK LID RELEASE TYPE - CABLE8124A1TRUNK LID TRIM - FULL COVER8131A1CENTRAL DR LOCK/UNLOCK - DR`S CONTROL8135A2INSIDE HNDL OVER RIDE - DR`S & PA`S SIDE8136A1CHILD SAFETY RR DR LOCK`G813AA1SPEED SENS`G AUTO DR LOCK813BA1IMPACT SENS`G AUTO DR UNLOCKG813XA1IGN KEY REMOVG AT DR UNLOCK8152A3FUEL FILLER DR REL TYPE - CABLE8195A1IGNITION ILLUMINATED - BULB TYPE819BA1KEYLESS ENTRY-PANIC819CA1KEYLESS ENTRY-T/OPEN8221A1DR FRAME MLDG - BLACK8235A1MAP POCKET FINISH`G - W/O T/C PILE8236A3ARM REST COVER`G - ARTIFICIAL LEATHER8237A1ARM REST HANDLE - PULL TYPE8241A2FR DR GLASS - TINTED8245A2RR DR GLASS - TINTED8261A4FINISH`G - CR COAT`G8262A2LEVER FINISH`G - CR COAT`G8341A2POWER WINDOW(FR+RR)8346A1TIME LAG POWER WINDOW834AA1AUTO DOWN8421D4N/PUNCH - STD842BA4FOOT REST - AL TYPE8443A1TRAY8451A1W/O LOCK8461B1DLX - PVC8462A1CUP HOLDER - FR(W/O ILL)846BA6W/ STORAGE BOX ARM REST - DLX(1 DIN)846EA1POWER OUTLET847AA3AIR OUTLET GRILLE - NORMAL TYPE CR COAT8491A1CTR FACIA PNL8492A1CONSOLE UPR COVER8499A1DOOR TRIM GARNISH8521A1MATERIAL - VINYL8522A1VANITY MIRROR - GLASS TYPE8523A1MATERIAL - VINYL852AA1TICKET HOLDER852DA1ILLUMINATED852EA1TYPE - EXTENSION852GA1VANITY MIRROR - GLASS TYPE852KA1ILLUMINATED852LA1TYPE - EXTENSION8531A2ROOF TRIM MATERIAL - FABRIC8532A1FR - 1 EA853AA2RR - 2 EA853JA1RR - 1 EA8561A1RR P/TRAY MATERIAL - PLASTIC8571C1LUGGAGE SIDE - W/PAPER8572A2RR - PLASTIC8573A2FLOOR - WALL PAPER858RA1DR SCUFF - STD858SA1STEP PLATE85APA1TOOL CASE(OVM TOOL)8612A1MLD`G-WINDSHIELD - BLACK8631B4B TYPE - BLACK+CR COAT`G863AC4CAR NAME - CERAT0863CA5GRADE - TOP8641A1TOWING HOOK8643A1SHIPPING HOOK8649B6ID PLATE - GEN+MES TYPE(ID)864EA1VIN LABEL - VIN8651B1TYPE - 2.5 MILE8652B1COLOR - BODY COLOR8711A1MLD`G-BACK LITE - BLACK8712B4BACK LITE GLASS TYPE -TINTED(W/ HEATED)871BA1RR HEATED W/ TIMER8722A3H.M.S.L - RR P/TRAY8731D1MLD`G - BODY COLOR+CR COAT`G8762C4PASS`S SIDE - ELECTRIC HTD-CONV8763C4DRIVER`S SIDE - ELECTRIC HTD-CONV8765A2COLOR - BODY COLOR876NA1SIDE REPEATER LAMP (O/S MRR)8821A1HEAD REST - UP/DOWN8823A1SLIDING8824A2DOUBLE RECLIN`G8825A4ADJUSTER - PUMP`G DEVICE882BA1ACTIVE HEAD RESTRAINT8854A1HEAD REST - UP/DOWN885CA1ACTIVE HEAD RESTRAINT885DA1SLIDING885EA2DOUBLE RECLIN`G886BA1SEAT BACK - SEAT BACK POCKET8881B1DRIVER`S SIDE - ELR8884D1PASSENGER`S SIDE - ELR8885A2RETRACTOR PRETENSIONER - ELECTRICAL TYPE888AA2PRE TENSIONER - ELECTRICAL TYPE888KA2S/BELT ANCHOR - ADJUSTABLE888RA2S/BELT ANCHOR - ADJUSTABLE8912D16:4 SPLIT BACK FOLD`G - BACK8913A1LH8914A1RH8981A4SIDE - ELR8982A1CTR - STATIC89F1A1W/ CUP HOLDER9211E3MFR - CLEAR9221A2CONVENTIONAL - CLEAR LENS9241A1CLEAR9282A1FR - W/ SUNGLASSES9287A1LUGGAGE LAMP928FA1CTR - GLOW LAMP928HA2FR - REFLECTOR9401B1CLUSTER TYPE - SUPER VISION9402A1SPEEDOMETER940AA3TRIP ODOMETER - LCD940BA1TACHOMETER940CA1FUEL940DA1WATER TEMP.940HA2TEMP - LOW9451A1TYPE - DIGITAL9491A1RHEOSTAT94C1A1A/T POSITION INDICATOR94C6A1DIRECTION INDICATOR94C7A1OIL PRESSURE94C8A1BRAKE OIL94C9A1PARK`G BRAKE94D0A1DR AJAR - DR AJAR94D1A1BATTERY CHARGE94D2A1HIGH BEAM94D4A1LOW FUEL94D7A1TRUNK LID(T/GATE) OPEN94D9A1CHECK ENGINE94E3A1SEAT BELT94E5A1A.B.S94E6A1A/BAG94G4A1FOG LAMP (FR)94M0A1SPEEDOMETER TYPE - KMPH94N0A1TEMPERATURE UNIT - C9511A1AUTO LIGHT CONTROL SYSTEM - 1 STAGE9541A1BODY CONTROL MODULE - BCM(ETACS)9545A1FREQUENCY-SMART KEY - DOMESTIC9571A3RR PARK`G ASSIST SYSTEM(RPAS)9614B1COMPONENT- 2 DIN9615A1FREQUENCY VIBRATION - AM9K/FM100K961AA1AUX961DA1USB+IPOD9621G1ANTENNA TELESCOPIC - ANTENNA ROOF TYPE963CA1SPEAKER LOCATION FR DR - GENERAL963MA1SPEAKER LOCATION QUADRANT INR COVER963ZA1SPEAKER LOCATION RR DR LOW-GENERAL9651A1TYPE - SEPARATED TYPE9661A1HORN - SINGLE967AA1AUDIO REMO.9711A2BLOWER - 4 SPEED FAN9714A1FUNCTION - AIR FILTER971CA1HEATER CAPACITY - STANDARD9721B1ELEC TYPE - ROTARY TYPE9741A1RR HEATING DUCTS - 2ND SEAT9811A2FR WIPER - INTERMITTENT(VARIABLE)9817A1MIST FUNCTION981AA1FR WIPER-2 SPEED
Code
Description
0101A7MODEL YEAR PACKAGE - 10MY5692A3PASSENGER SIDE - DEPOWERED5894A1ESC (ELECTRONIC STABILITY CONTROL)8161C4POWER-TOUCH SAFETY8196A2BUTTON START - BUTTON W/ ILLUMINATED8197A1FOB HOLDER W/O ILLUMINATED8198A3STEER`G LOCK TYPE - ESCL819HA1SMART KEY-FR DR8233C1CENTER TRIM - PVC834CA3SAFETY WINDOW - FR DR(DRIVER`S)84Q1A1CLUSTER FACIA PNL84REA1C/PAD UPR SKIN8511C1ELECTRIC CHROMIC MIRROR TYPE8611C1W/S GLASS TYPE-UV CUT8681A1MUD GUARD-FR8682A1MUD GUARD-RR8811E2PURE LEATHER9299A1W/ SUNROOF SW94H9A1E.S.P9611P9RADIO+CDC+MP3 - PA 760961EA1IPOD CABLE9761A3FR COOLER - FULL AUTO A/CONA26VIETNAM
Bác chủ check giúp em với: KNABA24327T487076
Ymeo của em là: nguyenluulee(a)yahoo.com (em chưa đủ tuổi chèn link bác thông cảm)
Em cám ơn bác nhiều lắm !
Nho bac kiem tra giup e: KNABZ511BCT156406
Email: tranlebang @ gmail
Cam on bac nhe.
