Re:Chuyên đề về Mercedes-Benz GLK 4Matic
Nguyên bản tiếng Anh về nội dung dịch vụ A, B của Mercedes:
A SERVICE: - Inspect and record tread depth, and correct tire pressure - Rotate tires (excludes AMG, Sports Models, SLK, and vehicles with staggered wheels) - Engine oil change and oil filter replacement -Includes Mobil 1 synthetic oil - Lubrication service - Includes hood hinges, lock cylinders, striker plates, sun roof tracks and top off all fluids - Cooling system inspection - Includes antifreeze protection level, hoses and clamps - Brake inspection - Includes check of pad thickness and condition of discs, fluids and lines - Inspect heating and ventilation dust filter, replace if needed. (Replacement additional. Dust filter prices vary by model) - Function check - Includes warning lamps, headlights, exterior lights, seat belts, windshield wiper and washer - Inspect and lubricate throttle linkage - Check and clean air filter - Reset flexible service system counter
B SERVICE: - Inspect windshield wiper inserts and service windshield washer system (Replacement of wiper inserts additional*). - Inspect and rotate tires, record tread depth, and correct tire pressure. (Wheel balance additional*). -excludes AMG, Sports Models, SLK, and vehicles with staggered wheels - Engine oil change and oil filter replacement -Includes Mobil 1 synthetic oil - Lubrication service - Includes hood hinges, lock cylinders, striker plates, sun roof tracks and top off all fluids - Cooling system inspection - Includes antifreeze protection level, hoses and clamps - Brake inspection - Includes check of pad thickness and condition of discs, fluids and lines - Inspect heating and ventilation dust filter, replace if needed. (Replacement additional*. Dust filter prices vary by model) - Function check - Includes warning lamps, headlights, exterior lights, seat belts, windshield wiper and washer - Inspect and lubricate throttle linkage - Check and clean air filter - Reset flexible service system counter - Inspect front axle ball joints; check steering play and power steering clutch; and rear differential levels - Inspect Poly V-Belt for condition - Inspect starting and charging system and service battery - Inspect climate control refrigerant
