4.041
20
HCM
Re:Lexus LS 400 - Niềm đam mê bất tận!!!
Lướt xợt nói:
Em hiểu 2 cái "ca thơ líc" này để lọc khí xả (cho đảm bảo sạch như quy định của luật Mẽo). Không bít hiểu vậy đúng không các bác?? Hơn nữa, nếu 2 cái đó tèo thì co ảnh hưởng gì tới hiệu quả làm việc của xe/máy móc không? Em hỏi thía là vì $300 to quá, phải cân lên đặt xuống nếu phải thay nguyên cặp này!
Cái catalytic này chủ yếu là để bảo vệ môi trường sạch hơn và xanh hơn thôi, các bác không tin thì tham khảo thử cái link này:
http://deccatalyticconver...r-catalytic-converter/
Being talked so much today about going green in lots of countries worldwide, the need and usage of a catalytic converter in virtually all vehicles seems quite easy to understand.
The harmful gases which are emitted from factories as well as car pollution are the main cause for several holes being found within the ozone layer. It is attributed to this undesirable pollution that we have noticed a drastic change in whether with exceptional breaking temperatures striking on a world wide scale. Lots of green activists consider that much more has to be done in regards to decelerate the damage that is being triggered to the natural environment. For this particular reason many really feel that the value and need of a catalytic converter is justified.
<span style=""color: #800000;"">However exactly what does a catalytic converter really do? The catalytic converter merely helps purify the smoke that is being contaminated into the air to help make it less damaging.</span> As you are all most likely aware off, the autos that we drive run on petroleum. If you take a look at petrol from a scientific perspective, it will be evident that it is acknowledged to create lots of carbon. Anytime this carbon breaks down, it enables the car to operate in the way that it does. Nevertheless in doing so, it provides of various harmful gases which include carbon monoxide. When autos were first created, the notion of using catalytic converters never existed. However as attention came to exist in relation to the damaging effects that the smoke emitted has on the encircling environment, things have considerably changed.
In all nations, the law demands every automobile that is found on the road to use a catalytic converter fitted in that is function efficiently. This is not of great issue if you have acquired any latest cars in this millennium as they have turn out to be a factory standard. You might need to check if your car has one in the event that it is really an old model. Seeing that there is an increase in the number of vehicles observed on the highway, many have sensed that using a catalytic converter is not sufficient to prevent the harmful effects of the gases being released. Although the converter helps purify the smoking, with their being a boost in the amount of cars polluting this smoke, it in reality doesn’t make much of a difference.
All vehicles are demanded to go through a yearly test which assures that the vehicle is not emitting more smoke than it is lawfully permitted to. These tests assure that all the vehicles that are being driven on the road will be equipped with an efficient catalytic converter that is full filling its objective. If you come across your car providing dark black smoke from the exhaust area, it is encouraged that you get it examined. It is very likely that your catalytic converter is no longer efficiently functioning and may need changing. This can mostly be due to the gas that you utilize for your vehicle.
Cũng có vài ý kiến trên net cho rằng nếu nghẹt cái catalytic này thì sẽ làm xe yếu đi và hao xăng hơn, thậm chí có hại đến engine nhưng chưa ai chứng minh rõ ràng hết, toàn đánh giá theo cảm tính thôi, nếu cái catalytic này hư hỏng mà làm tổn hại đến engine thì chắc chắn nó phải báo đèn Check rồi (đối với những xe đời mới sau này, do yêu cầu bảo vệ môi trường khắc khe hơn nên nếu cái catalytic mà bị clog là nó báo đèn Check liền)
Theo em nếu nhà có điều kiện thì nên thay, lợi ích thứ nhất là bảo vệ môi trường + tiết kiệm xăng (vì nếu nó bị nghẹt là đương nhiên hao xăng hơn), lợi ích thứ hai là khi chạy xe vô nhà không bị mùi xăng sống (còn lúc chạy ngoài đường thì người khác ngửi chứ mình có ngửi đâu :D) và lợi ích thứ ba là có cảm giác tự sướng giống bác kotex :p
Em nói sai thì các bác cứ sửa giúp em nhé, thanks.
4.041
20
HCM
LS400love nói:
Bác Gấu làm sao mà ở trong BV mấy ngày luôn vậy? Bác ốm hay người thân?
Thanks BS gây tê đã hỏi thăm, người nhà em nằm viện nhưng em phải làm Osin bác ui, hai tuần rồi :(
Của bác nè:
Hàng OEM chính hãng Toyota, anh có thể mua trên Ebay USA: http://cgi.ebay.com/ebaym...mp;hash=item5adb83c6c1
4.041
20
HCM
Trong cái link em đưa anh thì seller có nói rõ là 1 set 2 cái, giá bình thường là 300$/cặp (chưa ship) còn seller này đang giảm giá 210$/cặp (chưa ship). Theo em thì anh nên múc gấp, tiết kiệm được một mớ lúa, đầu tư vô cái này là đáng đồng tiền nhất, em với lão Hạc mần rồi
4.041
20
HCM
LS400love nói:
Tìm được cái này trên đó nè bác:
http://cgi.ebay.com/ebaym...em7QQitemZ220694898964
Cái này không gắn vừa xe anh đâu mà gắn vừa xe em, cha này bán rẻ quá, để em múc về làm spare part :D
Mịa, cái này nhỏ xíu vậy mà tiền ship nó đòi 35$
Cái hands free của xe anh nó bự hơn vì cái bát để bắt nó vô vô lăng của anh cũng khác, cái của anh cùng đời với duongxua và luotxot.
518
BMT
Thanks Gấu, mình sẽ tìm đường dây để múc về, đầu tư cho engine motor mount là đầu tư thông minh đáng đồng tiền bát gạo mà.
Mình còn đang lăn tăng tìm cái solenoid valve cho hộp số mà tìm chưa ra, khắc phục lổi 63 đó bác, chờ tìm thấy ship một lúc luôn.
518
BMT
gauxam nói:
LS400love nói:
94 trở đi mới khác Gấu ơi, mình nghĩ là được mà.
4.041
20
HCM
LS400love nói:
[/quote]
Khác đó anh ui, nó dùng cho đời 95 trở lên, không tin em thì anh cứ mua đi, kể luôn tiền ship là 50$ đó, mua về gắn vô không được thì cho em
