852
3.696
Thấy loại này để chuyên cho mạch điện, nhanh khô nè... chắc thay thế cho CRC MAF Cleaner được các bác nhỉ, không biết có bán ở SG không thôi.
Dùng rượu mạnh cũng được, alchol, hoặc là dùng cồn y tế 91%.
WD40 có để lại tạp chất, không dùng chai wd40 nhen.:
WD40 leaves a residue! Common isopropyl alcohol (70%) is ok, but better is the "medical" grade at 91% as it dries more quickly.
Simple acquer thinner is even faster, or its constituents: toluene, acetone, xylene, etc.
Just avoid anything oily, sticky, or melts plastic quickly!
http://forum.miata.net/vb/showthread.php?t=453604
No, don't do it!
WD40 will leave an oily deposit on the sensor and stop it from working properly.
http://www.briskoda.net/forums/topic/137473-can-you-use-wd40-to-clean-maf/
Personally I use rubbing alcohol, a bunch of Q-tips and a steady hand.
Although I haven't used it for years there is probably nothing wrong with using rubbing or isopropyl alcohol on MAF sensor wire elements and the thermistors. The advantage of the MAF spray cleaners available at any auto parts store is they allow no contact with the relevant parts of a MAF with the exception of pushing the spray button so Murphy's Law is not invoked. "What can go wrong will go wrong". Also, does not leave any residue.
This MAF sensor was replaced due to improper cleaning. Worked before removal, then set a MAF DTC after cleaning.
http://www.automotiveforums.com/t739290-cleaning_mass_air_flow_sensor_.html
Cách rẻ tiền nhất là mua chai cồn y tế (rubbing alcohol), rồi mua cái cây ngoái tai ( Q-tips) về rửa cái cảm biến là xong.
images
MAFs definitely need to be clean for proper operation.
I clean mine every ~15k miles or so, just to get the best possibile results from it. This is even more important for those people using K&N filters, since the filter oil can and does leave a bit of film residue on the MAF wires.
I've been using the rubbing alcohol and Q-tip method to clean my MAFs for at least 13 years now. Some people are terrified of this method and think it will damage it, but it absolutely will not damage it if you do it correctly and don't apply any pressure. I've tried the spray cleaners, and they are certainly better than nothing but they don't ever get the wires quite as clean as letting an alcohol soaked Q-tip gently glide along the surface of the wires.
Either way, keeping the MAF clean is always a good idea for best driveability and overall engine performance.
__________________
http://ls1tech.com/forums/general-lsx-automobile-discussion/1603218-maf-cleaner-works-great.html
Rửa bằng cồn y tế 13 năm rồi, xe vẫn chạy tốt. Lấy cây tăm bông, tẩm cồn rồi rửa nhẹ cái Mafs (gently).
Mấy anh sử dụng lọc KN nên vệ sinh Mafs thường xuyên hơn vì dầu của lọc gió KN có bám vào sợi dây cảm ứng của cái Mafs ( the filter oil can and does leave a bit of film residue on the MAF wires)
Và kết luận rửa bằng cồn y tế sạch hơn rửa bằng chai cleaner
I'm glad this was helpful to you.
I am a firm believer in using this method, especially when K&N-type filters are in use. A spray cleaner by itself never seems to get the wires fully clean. Like I mentioned in my earlier post, I've been doing it this way for over a decade now and have never damaged any MAF using my routine. It's just a matter of not applying any significant pressure, just let the q-tip glide over the surface exactly like you did.
__________________
852
3.696
bác xem giùm em chai này vệ sinh được ko ah
Chai này là chai electronics contact cleaner, dùng để vệ sinh mạnh điện, tụi nước ngoài nó cũng dùng chai này để vệ sinh cảm biến gió, Maf sensor, ok, không có vấn đề gì. Sau khi vệ sinh phải đợi cho nó khô (30 phút cho chắc ăn đi) thì hãy gắn vào và nổ máy nhé.
Do chữ nhỏ nên tôi chỉ đọc đc chữ (complete evaporation) nghĩa là bay hơi hoàn toàn có nghĩa là dùng được... (nghĩa là không có hóa chất bám lại, non residue, sau khi sử dụng chai này để vệ sinh ). Vì nếu có hóa chất bám lại sẽ làm hư cái sensor.
Loại này chợ Dân Sinh có bán, vài chục ngàn, hiệu Abro, USA.
You can use any non residue electronic parts cleaner on the MAF. I usually end up getting a can from Altex, Radio Shack, and some Office Depot or Office Max stores carry the cleaner also. Just spray it down real well and let it dry.
You can use CRC QD electronics cleaner without ANY worry. It is almost the exact same product as the MAF product. The important part is that CRC QD (like the MAF cleaner) is SAFE for plastics, and has NO residue that can be left behind. QD does as good a job cleaning the sensor as MAF cleaner and will clean safer and BETTER than the alcohol will.
Tụi nc ngoài nó còn khen chai vệ sinh mạch điện dùng còn tốt hơn cả chai cồn alcohol nữa.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1528722
Động cơ trc khi vệ sinh cảm biến gió, MAFS
Động cơ sau khi vệ sinh MAFS,
http://www.carcarenewsservice.org/a...-flow-sensor-restores-lost-mpg-and-horsepower
Như vậy, động cơ tăng được 10 mã lực và Moment xoắn tăng được 3 đơn vị.
Kết luận nên vệ sinh cảm biến gió. Công việc này, các garage ở VN hầu như chưa bao giờ làm.
74
128
Cái throttle plate & throttle body thường được phủ 1 lớp coating để giảm bám muội than. Xài mấy loại cleaner bậy bạ làm tiêu lớp phủ này còn rách việc hơn nữa. Tìm chai nào có ghi "Safe for Coated Throttle Body" mà mua cho chắc ăn
7.464
2.743
Vậy mình dùng chai vệ sinh bướm ga như bên dưới để vệ sinh cho các bướm qua và MAF Sensor được luôn không các bác?
Mua chai vệ sinh cảm biến gió (MAP/MAF) ở đâu?
Hay bắt buộc phải dùng chai đặc trị như bên dưới, em thấy thị trường VN mình ít thấy bán chai MAF Sensor cleaner này.
Reactions: thevinh78
901
381
Sài Gòn
Ko có bán luôn chứ ít gì bác. Ae toàn ship hoặc nhờ ship về dùng
Reactions: huy812000
711
1.475
AE hội Bim hầu hết đều có 1 chai trên xe :)
https://www.otosaigon.com/threads/diy-ve-sinh-maf-cam-bien-do-gio-de-tiet-kiem-xang.8679095/page-5
