34
e up cái này chơi :D
[font="arial, helvetica, sans-serif"]Be aware of potential problems with incorrect off-set (ET) rims on the Niva. The lowest you should go with a Niva is probably around 30 or 40mm (as long as the backspace isn't risking contact with the body etc with wider than stock rims).[/font]
[font="arial, helvetica, sans-serif"]Lada
Niva (2121, Hussar, etc) – fitted with 16” x 5” wide, (ET55/57mm, ie a High offset)
Wheels: disk stamped, rim size 127J-406 (SJ-16). Tyres: radial-ply 175/80R16 with 315 mm static radius or cross-ply 6.95-16 (175-406) with 322 mm static radius.
Cossack (aka Turist, Toro, etc) OEM rims - 15” by 5.5 or 6, (H offset), different brands (ROH, BWA, etc) vary slightly in different markets. [/font]
[size="-1"]Suzuki rims on a Niva; note the much lower off-set than Lada rims (see warning below).[/size][/font]
[font="arial, helvetica, sans-serif"]Suzuki
LJ 80, SJ 410, SJ413, Jimny, Samurai, Escudo, Sierra, Caribbean, X-90, Vitaras & some Grand Vitaras – mostly 15 x 6 (L/M offset, -10...15mm)
Sidekick (USDM) �96 - �97, 16 x 7 (M offset)
Vitaras & some Grand Vitaras (USDM) ’98 -, 16 x 7 (L offset)[/font]
[font="arial, helvetica, sans-serif"]Maruti / Maruti Udyog
Gypsy mostly 15 x 6 (L/M offset, -10...15mm) (Indian licence built Suzuki SJ)[/font]
[size="-1"]16" Kia Sorento rims[/size][/font]
[font="arial, helvetica, sans-serif"]Kia
Sportage some early Sportages are rumoured to have a high offset of around 30mm, but I've never been able to confirm this.
Sportage '93/�94 on, 15 x 7 (L/M offset, 0...-3mm) (later Sportages have 6 studs)
Rocsta
Sorentos '94 on, probably 16 x 7s, (L, 0-3mm)[/font]
[font="arial, helvetica, sans-serif"]Daihatsu
Taft/Scat: F10, F20, F25, F50, F55, F60, F65
F70/Fourtrack/Rugger/Rocky/Wildcat/Feroza – probably 15’s (offset 0...-3mm)[/font]
[font="arial, helvetica, sans-serif"]Dodge 2
Ram 1500 4WD
Ramcharger ’79-’83, 15 x 6.5 (all L offset)
Ram Charger ’88 – ‘93
Ram ½ ton truck (2wd and 4 x4) ’94 on, 16 x 7
Ram van ’85-’96, 15 x 7
½ ton truck 4x4 ’79 – ’83, 15 x 6
� and � ton truck �84 � �93, 15 x 7[/font]
[font="arial, helvetica, sans-serif"]Holden
Drover (Australian rebadged Sukuki SJ) (L/M offset, -10...15mm)[/font]
[font="arial, helvetica, sans-serif"]HopeStar
ON360 (progenitor of the Suzuki LJ)[/font]
[font="arial, helvetica, sans-serif"]Jeep
All CJ Jeeps ‘46 – ‘85 have 5x139.7 15” with either 4.5/5/6” rims (L offset)
Also Jeep full size trucks and wagons up to 1972; & C-101 Jeepster Comanando '67 to '74 (don�t mistake them for the 5x114 fitted to Cherokee/Wrangler and modern 5 stud Jeeps)
Jeeps (licence built):
Mahindra (Jeep, India), Mitsubishi (Jeep’53 – ’98, Japan), Willys Colombia (Jeep –’99), Willys Overland do Brasil/Ford (Jeep ’54 – ’83, Brazil), Kaiser Argentina (IKA) (Jeep ’56 – ’78, Argentina), Türk Willys Overland (Jeep – ‘80s) Hotchkiss (Jeep ’54 – ‘70s, France), Nekaf (Jeep ’56 – ’62, Netherlands), EBRO (Jeep ’53 - ’85, Spain), Hadonghwan ('54-??, South Korea), Pars Khodro (Iran). All unconfirmed - certainly 5 stud, and very very unlikely to be anything else.
Note: this also means you could potetialy use a Dana diff and keep stock rims.[/font]
[font="arial, helvetica, sans-serif"]Ford M151 “Mutt” jeeps ’59 – ’78 (unconfirmed - certainly 5 stud and very likey to be based on the Jeep PCD; they also they have a pretty H looking offset). Early MUTTs had cast mags (oval slots).[/font]
[font="arial, helvetica, sans-serif"]International Harvester
All Scouts have 5x139.7[/font]
[size="-1"]Amercian 15" rims[/size][/font]
All USDM Fords '28-'48 (?)
Mercury - all '39-'51
Post-WWII “Jailbar” pick-ups
F series trucks �54 � �95, 15 x 6 (L offset) (don�t mistake them for the 5x135s the �96- F 150s had)
Lincoln - all '52-'60
Bronco �66 � '96, 15 x 6 and 7, (L offset) (don�t mistake them for the 5x114 the Bronco II (�82 � �90) had)
½ ton E-100, 150 van, ’70 – ’96, 15 x 6, (L offset)
Econoline E150, ’88 – ‘94
Note: this also means you could fit the legendary Ford 9 inch diff - and keep stock rims.[/font]
[font="arial, helvetica, sans-serif"]Chevrolet / GMC
Tracker, Vitara (USDM) ’98 on, 15 x 6, 12mm X 1.25 (L/M offset, -10...15mm) (US rebadged Suzuki)
Niva 2 (re-badged Lada)[/font]
[font="arial, helvetica, sans-serif"]Pontiac
Sunrunner (Canadian rebaded Suzuki) (L/M offset, -10...15mm)[/font]
[font="arial, helvetica, sans-serif"]Chrysler
8 cyl. & wagon '46-'55
Imperial '54-'66[/font]
[font="arial, helvetica, sans-serif"]Geo
Tracker 2WD 1989-1998[/font]
[font="arial, helvetica, sans-serif"]Toyota
Blizzard (re-badged Daihatsu)
Landcrusier V8s are listed as 5x1.39.7s in Russia, but I suspect an error (ie actually 5x150 as the �Cruiser is listed in other markets, but who knows maybe their V8 'Cruisers have Daihatsu bits for some bizzare reason).[/font]
[font="arial, helvetica, sans-serif"]Delta Motor Corp (Phillippines)
Mini Cruiser (Daihatsu F20 based miniture version of the Toyota FJ40), (unconfirmed - certainly 5 stud, and unlikely to be anything else)[/font]
[font="arial, helvetica, sans-serif"]Morris
Commercial LC3 – LC5 (‘50s) (unconfirmed, and seems unlikely but looks right, need numbers?)[/font]
[font="arial, helvetica, sans-serif"]Mazda
Proceed (Japanese market rebadged Suzuki) (don't confuse with non-Suzuki based Proceeds)
AZ-Offroad (Japanese rebadged Suzuki Jimny) (L/M offset, -10...15mm)[/font]
[font="arial, helvetica, sans-serif"]Mahindra
Scorpio (unconfirmed - 5 stud, and they make Jeeps so maybe...)[/font]
[font="arial, helvetica, sans-serif"]Tata
Safari (unconfirmed - 5 stud, but they made Mercs so maybe not)[/font]
[font="arial, helvetica, sans-serif"]UAZ
various (ET 20, 106.0 mm, 6x15, 6x16)[/font]
[font="arial, helvetica, sans-serif"]LuAZ
various amphibian & utility models (unconfirmed, but they look right and were once owned by AvtoVaz), Offset High[/font]
[font="arial, helvetica, sans-serif"]GAZ
GAZ-69 [/font]
[font="arial, helvetica, sans-serif"]Rolls Royce/Bentley
Silver Cloud/Phantom – the ultimate 18� �bling� rims for a Niva if you can ever find a set.[/font]
[font="arial, helvetica, sans-serif"]Bertone Freeclimber
Daihatsu based Italian 4x4 (powered by BMW!)[/font]
[font="arial, helvetica, sans-serif"]Volvo
C202 & Valp L3314 models (not the C30 models which have an 8 bolt pattern) had 6.50-16" or 5.50-16" rims [/font]
[font="arial, helvetica, sans-serif"]Santana
Vitara and 300/350 (Spanish rebadged Suzukis) (L/M offset, -10...15mm)[/font]
[font="arial, helvetica, sans-serif"]Willys
Pick-ups[/font]
[font="arial, helvetica, sans-serif"]ZhanQi
BJ 212 - 2020 (Chinese UAZ 469 clone; unconfirmed, but given it's a UAZ clone and that there's pictures of one with what looks like Suzuki rims they are almost certainly 5 x 139.7)[/font]
[font="arial, helvetica, sans-serif"][size="+1"]Offset Guide:[/size]
H = high or positive offset, typically +45, 40, 35mm (typically front wheel-drive)
M = typically + 20mm offset
L = low, typically 0 or negative offset[/font]
1.921
408
Ổi bơ nói:
em thì đang mơ có một chú niva như thế này bác ạ, tiền độ quá tiền xe :D
Phấn đấu phấn đấu phấn đấu :x
Với lốp cỡ này trên khung gầm Niva thì cảm giác lái chắc "thích" lắm, chưa chắc đã kém lái công nông đầu dọc là mấy. Nếu là em thì em mua cái máy kéo để leo trèo cho thỏa chí chứ không làm thế này.
34
mig19farmer nói:
Ổi bơ nói:
Có thể làm trợ lực lái mà bác, nhưng em cũng không thích chân quá to như thế
525
Thưa các bác
Tranh thủ Tết em ngồi đọc tài liệu Niva và dịch để hiểu thêm về em nó. Em đang quan tâm đến bộ chế hòa khí nên dịch nó trước. Bài dịch dài nên em để ở đây:
http://sites.google.com/s...eu-dich/bo-che-hoa-khi
Em làm một ngành hoàn toàn khác nên dịch hơi bị khó, tra từ điển mệt luôn, nhiều từ chuyên môn không chắc bên VN gọi như thế nào. Các bác tham khảo chơi và góp ý cho bài dịch hoàn chỉnh nhá. Em định dịch hết quyển sách Niva in dạng đánh máy chữ đó (tải về từ hồi 2004), nhiều thứ hay lắm. Tiếp theo em sẽ dịch phần máy.
34
Giờ tìm một em niva còn 2 cầu khó thật, em thấy bảo Daklak có nhiều không biết có chuẩn không.
1.921
408
Ổi bơ nói:
[/quote]
Trợ lực lái không giải quyết được vấn đề gì đâu bác. Thay bánh quá lớn so với thiết kế thì cả hệ thống truyền động đều làm việc quá tải. Xe sẽ rung lắc kinh khủng và mọi thứ sẽ nhanh chóng xuống cấp. Chưa kể với động cơ cỡ Niva thì với cặp bánh này thì phải độ thêm đủ thứ như thay đổi tỷ số truyền của hộp số phụ và các cầu trước sau nếu muốn xe có thể chạy được. Với số tiền đó thì ta đi mua một cái xe mới có bánh béo cho xong. Em thấy Niva cứ bánh cao lêu nghêu là hợp nhất, leo trèo vô tư dù trông hơi quê.
