Các vấn đề và các model phải recall của To, nguyên nhân của việc To. bị mất 20 tỷ USD trong vòng 1 tuần:
1. Dính thảm chân: (~5 tr. xe recall)
Các model:
Năm Model:
2007–2010 Lexus ES350
2006–2010 Lexus IS
2005–2010 Toyota Avalon
2009–2010 Toyota Corolla
2007–2010 Toyota Camry
2008–2010 Toyota Highlander
2009–2010 Toyota Matrix
2004–2009 Toyota Prius
2005–2010 Toyota Tacoma
2007–2010 Toyota Tundra
2009–2010 Toyota Venza
2009–2010 Pontiac Vibe
2. Dính chân ga: (~2.3 tr. xe recall)
Các model:
Năm Model:
2009–2010 Toyota RAV4
2009-2010 Toyota Corolla
2009-2010 Toyota Matrix
2009-2010 Pontiac Vibe
2007-2010 Toyota Tundra
2008–2010 Toyota Sequoia
Khuyến cáo chính thức của Toyota:
Each circumstance may vary, and drivers must use their best judgment, but Toyota recommends taking one of the following actions:
1. If you need to stop immediately, the vehicle can be controlled by stepping on the brake pedal with both feet using firm and steady pressure. Do not pump the brake pedal as it will deplete the vacuum utilized for the power brake assist.
2. Shift the transmission gear selector to the Neutral (N) position and use the brakes to make a controlled stop at the side of the road and turn off the engine.
3. If unable to put the vehicle in Neutral, turn the engine OFF. This will not cause loss of steering or braking control, but the power assist to these systems will be lost.
4. If the vehicle is equipped with an Engine Start/Stop button, firmly and steadily push the button for at least three seconds to turn off the engine. Do NOT tap the Engine Start/Stop button.
5. If the vehicle is equipped with a conventional key-ignition, turn the ignition key to the ACC position to turn off the engine. Do NOT remove the key from the ignition as this will lock the steering wheel.
Thông tin để nếu có bác nào lỡ bị dính chân ga thì nên sử dụng 1 trong các biện pháp an toàn đã được To khuyến cáo ở trên!
